Question about Dell 1600n All-In-One Laser Printer
DELL 1600n drivers for 2003 Server (Network Scan)
Unable to find a driver for Dell 1600n that will work with Windows 2003 Server (scanner).
  • vladislav_co Nov 27, 2008
    To vegakitten20:
    R165289.EXE this one is for XP and 2000, but not for 2003Server. Unfortunately they are not compatibility. Exist some drivers that can run correctly for 2003Server?
  • 849 Answers
  • 685 Answers
  1. Click the file name below to download the driver:
    R165289.EXE
    DELL 1600n drivers for 2003 Server (Network Scan) - new_note.jpg Note: By downloading, you accept the terms of the Dell Software License Agreement.
  1. Click the Save button.
  2. On the Save As: window, verify that the R165289.EXE file name is listed in the File name: box, and then click the Save button.
  3. On the File saved window, click the OK button.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Posted on Nov 26, 2008
All functions work on my 1600n printer with the exception of the scanner. The workstation names that normally appear when a doc is scanned do not appear
The Dell 1600n requires that the Dell Network Scan Manager is running. Windows Vista and Windows 7 require user level authorization for this app to run properly and may be prompting you at start up. If you are telling it "no" when propmted then this is one thing that can be hanging you up. It is also possible the app is simply not running at all. Go to start>programs>Dell>Network Scan and see if it picks it up then. This app is how the dell printer itself gets the names to put in the list of available workstations to scan to.
Jul 26, 2011 | Dell 1600n All-In-One Laser Printer
Unable to locate disk to install our Dell Laser MFB 1600n printer after CPU had to reinstall windows and now the printer is not working.
You do not say which version of Windows, so I am providing a link to the Dell Driver page for that model:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PRN_LSR_1600N&os=WW1&osl=en&catid=&impid=
Feb 23, 2010 | Dell 1600n All-In-One Laser Printer
Audio/sound driver for windows 2003 server operationg system
Go to: http://support.dell.com Enter your service tag# for your Dell machine, navigate to drivers/downloads, select driver for sound card and install.
gurutim
Mar 21, 2009 | Computers & Internet
Dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n printer driver for Windows 2003 Server
I had a similar problem deploying these printers, however i found using the XP drivers in 2003 does work fine. Not sure why dell doesnt have an installer for this printer in 2003 server, but here you go.
ftp://ftp.us.dell.com/printer/R165289.EXE
extract that file, note its destination directory. do not attempt to run the setup.exe, it will fail saying your operating system is not supported.
instead navigate to (if you didnt change the path) C:DelldriversR165289p0nPrinterPCLWINXP
this folder contains the driver you need to install manually.
one stange thing about these lexmark based network printers is the need to select 'local printer' during install, uncheck automatically search for my device, and then create a new TCP/IP port. Use the IP address provided by the network configuration print out you can access on the front panel of the printer. now just make sure to select 'lexmark network card' as the type of network interface. it should now ask you for your printer type, click have disk, and point to the driver folder mentioned earlier.
hope this helps. thanks alot dell.
Oct 30, 2008 | Dell 1600n All-In-One Laser Printer
Windows Vista can't find networkd Dell 1600n
Make sure you're using the drivers for Vista, which can be found on support.dell.com. You'll want to use the choice for Vista 32-bit.
Also, try turning off your firewall, as it may be blocking the network data.
Dec 15, 2007 | Dell 1600n All-In-One Laser Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
673 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
