Question about Hobart A200 Stand Mixer
Hobart A200 noise
I'm wondering if you can help me diagnose a somewhat loud Hobart A200 mixer.  It is an older model, serial #794389.  I have not tested under a full load, but below are videos of it without a load and kneading a small (5lb) dough.  The noise on high (3) speed is most pronounced and sounds like a bearing but more of a tick at speed 2 and a more continuous rattle at speed 3 than a whine.  Any idea what might be causing the noise?  There's very little play in the planetary shaft sideways but a little movement up and down... I might be able to measure it with a dial gauge but it's too small to estimate by hand.  I was told that it has been sitting idle for a few years and I'm wondering if I should pull the transmission and repack it with grease.  How difficult is this to do?  The exploded parts list is impressive and I'm curious if re-greasing is something a mechanically inclined engineer could do?  Would you be able to post some instructions?
No load:
Small dough:
Many thanks!
  • 135 Answers
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Posted on Jan 07, 2009
    New Friend:
  • 20 Answers
The sound you are hearing is most likely from the Internal Gear a gear that the planetary gear rides on while mixing -- this gear may not look warn, but it is needing to be replaced along with the gear on the beater shaft. Replace both of these gears -- the internal gear and the planetary gear that rides on the inner rim and you will not hear that noise any more!
Posted on Aug 23, 2014
  • J. Hobart Tech Aug 23, 2014
    Oops -- I meant WORN as in Worn out Gear!
  • 41 Answers
You may have stripped the clutch you will have to take it apart and look at it or you could have broken a key either way you have to open it up
Posted on Dec 09, 2008
Dc-sm168
Hello, Go here for beaters for your mixer: Hobart Mixer Parts Hobart Mixer A200
Jun 02, 2014 | Hobart A200 Stand Mixer
How do I empty and then refill the grease in the gear box of my 30 quart Hobart mixer
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
May 05, 2011 | Hobart A200 Stand Mixer
Hi i have hobart mixer 220v and it start to make loud noise when the dough get harder .thank you
What is the model and ml # on the data plate?I'm a hobart tech and repair these mixers often,let me know.
Nov 20, 2009 | Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Feb 23, 2009 | Hobart A200 Stand Mixer
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
Hobart A200 noises
Hi, here is my opinion: 1) your planetary, or attachment hub is making the noise as it goes around, and there is grease in the gear ring that keeps it lubricated, it may be as simple as removing the planetary grease ring ( the chrome ring), and taking loose the bolt and lowering off the hub and cleaning the old grease, and installing new, reassemble in reverse. You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing. How far you want to go is up to you.
For your other problem, I have seen the brass clutch bearings stick on the main shaft in the transmission, causing the planetary to momentarily speed up, or to maintain a wrong speed ( 2nd or 3rd) when set to first, but that would require full disassembly of the transmission. Best left to someone who has done it before, but if your inclined, go for it, but get a part breakdown first, or take pics as you go. Hope at least some of that helps, and thank you.
Nov 25, 2008 | Hobart A200 Stand Mixer
Hobart A200 diagnosis
the first A-200's have a worm gear drive that will slip when old but also when mixing dough somtimes the dough will push the mixer aherad of its self and look like its slowing but its just catching up. if you have a old worm shaft it will have a spring on it is how to tell. it is replaced with a shaft that is all keyed and has no slip or give unless a key shears.
Michael
A200 HP rating
yes the early models had 1/3 the later 1/2 but I think it was more a marketing thing to keep up with competitors the 1/3 always worked fine
Oct 28, 2008 | Hobart A200 Stand Mixer
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Feb 18, 2008 | Hobart A200 Stand Mixer
A200 problem
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
Feb 04, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
446 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
