Question about Ricoh Office Equipment & Supplies
Ricoh aficio 1232c. The registration clutch SP 5804-11 is not making clicking sound in output mode. It jams at point B when duplexing. What part do I need and would cleaning this reg clutch out help?
  • 30 Answers
You need a new registration clutch then probably part number is AX20 0240 i believe but if the reg clutch is faulty i would usually replace all feed clutches at the same time other part numbers are AX20 0239 relay clutch x 2 and AX20 0224 feed clutch x 2
Posted on Nov 27, 2008
Copies and prints are always approximately 7 millimeters too much in the left side on the paper
you need to adjust the lead edge trim
press yellow C and 107 and press and hold red C button
then go to copy SP
select 2 drum
then look for trim adjust
and then select front
then change values up and down until you get the correct registration. you can do a test copy while on SP mode by pressing copy window.
Sep 19, 2014 | Ricoh Aficio 1232C Color Copier
Why duplex paper jam in ricoh 3045
Clean the roller with water or Isopropyle Alcohol. It works 100%.
Aug 31, 2014 | RICOH - PRINTERS Ricoh Aficio Sp 3410dn -...
Ricoh Aficio sp 5200DN printer has new cartridge toner but machine do not work & display shows replace cartridge (out of toner) how to solve this problem?
you had to go in sp mode to reset the new inserted cartridge.Have you try it before & if not the machine is in auto jammed mode due to no tone left....... sawadee kap
Sep 13, 2013 | Ricoh Aficio SP 5200DN - Printer - B/W -...
How do I clear Fuser oil low message on Ricoh Aficio 1232C after refilling fuser oil bottle
At the machine. Press in this order. Clear all ( yellow button) then 107, then press and hold the pink stop button until the screen changes. You will see some icons that say Copy SP, Sytem SP.
Select Copy SP, if thats not available select System SP.
You will see several buttons. Select sp 7 Data Log, Then scroll to page 804 and select that. Then scroll to item 11. That is where you will select to clear the fuser oil count and reset it.
Jan 28, 2011 | Ricoh Aficio 1232C Color Copier
I need enter in factory service mode to enter serial Nº by code SC195 in aficio 1232.
press the clear mode key and use the key padto enter '107'hold downe clear\stop key for 3 sec enter the service mode and press on the touch panel sp mode and you can work what ever you like
May 20, 2010 | Ricoh Aficio 1232C Color Copier
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh AF811dn duplex registration is off. What are the codes to get into it and adjust them? Or does someone know where service information can be obtained?
If is only a little bit then its user tools, copy, and edit , set all to 0. If its alot then SP mode in the 1XXX it will have options for duplex adj.
-Carl
Jun 30, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
Paper Jam from the duplex into the Main Unit
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Dec 11, 2008 | Ricoh Aficio AP3800C Laser Printer
111 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
