Question about Microwave Ovens
How to set up matsui microwave oven.
My matsui 320 went off due to a power cut, i have tried resetting it, but so far i only can manage to reset clock. the two dots continuew to flash on clock, and i forgot how to do the rest. can you helpplease?
  • Microwave Ovens Master
  • 9,098 Answers
If for some reason you don't have your owner's manual, I would suggest calling the dealer you purchased it from.
They may have a contact phone number for Matsui.
Posted on Nov 27, 2008
My microwave was set at 20 minutes 17 minutes it went blank
Good Afternoon Friend, this is Z. Thank you for your post!
Let's try resetting your microwave by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, then it could possibly be a few things: faulty fuse, open thermostat, TCO (thermal cutout), magnetron, a bad connection with the control board or a potential wiring failure. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your microwave.
May 19, 2014 | Frigidaire Microwave Ovens
I have a microwave (Emerson Model#MW8111 SS and after removeing the cover to determine why I am not getting power I found a switch in line with the nuetral wire that is some sort of Klixon. It appears to...
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset-if the fuse is blown, it must be replaced. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the thermal fuse.)
Jan 12, 2018 | Emerson Microwave Ovens
The display window is stating the oven is in "demo mode". We did have a power failure prior to this function happening. What can we do?
I had the same problem after a power cut and eventually thought of switching it off at the mains and turning back on after a couple of seconds... it worked. Just needed to reset the clock and off I went!!! ;-)
Feb 05, 2011 | Panasonic NN-T888S Convection/Microwave...
GE Microwave JE1640 power went out, then came on later with ''reset'' message on display. What does that indicate?
The "RESET" indicates that there was a power failure. You should be able to push the clear/reset button and then set the clock and be on your way.......
Sep 14, 2009 | GE JE1640 Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Will not heat
No, you would need to do a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Jan 22, 2009 | Maytag MMV5207A Microwave Oven
I have a matsui 320 microwave oven, had it for some years now and can't find manual, we had power cut lately so microwave went off, i just cannot remember how to set it back up. any ideas now . if i press...
Otherwise, here are some sequences to try:
CLOCK SETTING
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Nov 26, 2008 | Microwave Ovens
Goldstar
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, you may have a failing keypad. It can fail due to age, moisture, etc.
PLEASE Let us know if the hard reset doesn't fix it.
We have the service manual available to us.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | Goldstar MA-2117W / B 1150 Watts Microwave...
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
417 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
