Question about kawasaki Full Suspension Mountain Bike Men
1996 bayou runs for short time ,keeps stalling out
Starts good, runs for short time and stalls. After sitting for ten minutes starts up and runs and then repetes same problem. checked carb, looks clean. New gas, clean air filter. New spark plug
  • Anonymous Mar 17, 2014
    honda 300 fourtrax wont start new plug freshly cleaned carbs new air filter getting fuel fire and air why wont it start???
    New Friend:
  • 41 Answers
Hello, I would start first, make sure ex pipe is open . Then I would check the pick up coil, ohms should be 390-590 on a 300 KLF. Do this test before u start the bike Then start the bike and when it quits running check the pick up coil ohms. If good move on to the coil, If good then I would say good chance CDI is bad I hope this helps
Posted on Nov 26, 2008
  • 4 Answers
Carbs will need rebuilding
sounds like running only on choke
also need to check valve clearance and petcock
Posted on Dec 19, 2008
Car runs perfect then starts missing real bad then stalls
Not unusual for fuel pumps to begin to fail once they are heated up from running. First thing in the morning pump is cool, then as you drive, it heats up and begins to lose pressure. After sitting a 1/2hr-1hr, it may start again and run fine for a short time and start to act up again. Had similar problem and found good fuel pressure when tank and pump cool, but lost pressure once vehicle driven a distance and pump heated up. The hotter the weather, the shorter the distance I could drive. If you can somehow set it up to have fuel pressure checked when it starts to act up, that would certainly help confirm if fuel pressure is the culprit.
Jan 10, 2013 | 1996 Dodge Stratus
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Replaced ignition lock cylinder and new key has no chip so it will turn over but now wont start. what to do?
CHARGE BATTERY / TURN KEY TO RUN POSITION FOR TEN MINUTES
SECURITY LIGHT SHOULD GO OUT / TURN KEY OFF FOR 3-5 SECONDS
TURN BACK TO RUN FOR TEN MINUTES / REPETE / USALLY TAKES
3 TEN MINUTE CYCLES / THAN TURN OFF / TURN ON SECURITY LIGHT
SHOULD GO OUT AND ENGINE START AND RUN
Dec 08, 2010 | 1996 Oldsmobile Cutlass Supreme Coupe
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Changed spark plug, air filter. Starts right up after sitting several hours but stalls within minutes. Have never experienced starting or running problem.
Check your spark arrestor in your muffler and see if it is plugged. Also check the vent in your fuel tank. Could be the cap or a vent tube in the tank. Has it sat around all winter and now it gives you these syptoms it could be a clogged filter in the tank due to the fuel varnishing or plugged jets or needing a carb overhaul. I would check the other two first before you get into looking at the carb. Good luck
Sep 26, 2010 | Garden
92 lumina apv stalls after sitting short time
here are some signs of a bad fuel pressure regulator: the vehicle runs rough, the engine will not start(usually in morning) MANY TIMES ENGINE STARTS BUT STALLS SHORTLY AFTER STARTING. a bad regulator can result in fouled spark plus, and fuel milage will decrease noticeably. the only cure is to replace regulator. what makes it fail usually it gets a tear in the diafram and it cant maintain fuel pressure. hope this helps toolman,
Mar 18, 2010 | 1992 Chevrolet Lumina
400 Eiger ATV, starts and runs fine, stalls the
If 2 stroke check crank seals, check plug cap for proper resistance,check for good fuel flow to carb.Spark should jump at least a 1/4" gap,NOT JUST the .030 or plug gap.
Sep 08, 2009 | 2004 Suzuki DR-Z 400 E
kawasaki Full Suspension Mountain Bike Men Logo
532 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
