Question about Western Digital My Book Pro Edition II WDG2TP10000 1 TB FireWire 400 (1394a) Hard Drive
Mount with Firewire 400 fails: WD MyBook Pro EII WDG2TP10000 1TB
After changing one defective drive (Drive B.), and reformatting under Raid 1. (mirror) everything works with a USB 2 connection, but I would like to connect the MyBook unit to my Firewire hub.
Now I cannot even get the unit to mount when directly Firewire-liked to my PC.
The drivers are supposed to be installed as soon as I insert the WD Software CD-Rom, but it seems that the Firewire link is not recognised.
Strange that the USB-link works.
Would be very pleased if you can suggest a solution.
Many thanks = John
  • 96 Answers
Hello. You may have erased some firmware drivers, or even have a bad connection on the unit. The easiest solution (if still under warranty) is to get the unit replaced. if not then you may have to make a visual inspection of the PCB at the iee1394 port (firewire/i-link) connection and make sure nothing is loose. if that fails, you may have to look up the particular company and request the firmware.
Posted on Nov 27, 2008
Lacie raid drive failure
You have a failed RAID array. These guys do raid recovery remotely over the net... http://FreeDataRecovery.us
Sep 09, 2012 | LaCie 2Big Quadra 6TB 2Disc RAID External...
How do I reformat a WD ext hard drive that is currently formatted to mac I wont to reformat to Microsoft
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Sep 23, 2010 | Western Digital WDG1C2500N MyBook Premium...
Western Digital MyBook suddenly no more responding. It worked perfectly over years, but one morning I entered the office, and the blue rings were on. But iTunes didn't play any songs, the library is...
You may be able to remove the hard drive manually and try another USB adapter to access it on your computer.
Might be pootched though.
Rule of thumb is to never save your files to only 1 source. Its not a question of if a hard drive is going to fail but WHEN.
Sep 26, 2009 | Western Digital 500GB MyBook Office...
My 1 terrabyte Mybook drive says it needs the raid installed. It doesn't have a raid. It's not working and It's been my disk for my mac time machine backup. Can you get it working again? Here's the...
It sounds like this drive is configured with two drives running RAID 1 (mirroring). If one of the drives inside the case has been removed or has failed, it needs to be replaced with an identical drive so it can resume mirroring.
Raid 1 requires two had drives. Both drives are kept absolutely identical so that if one fails, the other continues to serve your files, but you will get a message like the one you have reported to let you know that a drive is missing or has failed.
If you look in the case and there is only one drive, but a place for a second, then someone has removed the drive.
If you look in the case and there are two drives, then the drive identified as Drive B has failed or has become disconnected, try re-seating the drive and check any cables or power connections. If it begins to work then, you may have solved the problem, otherwise you will need to get an identical drive and put it into the case. The raid controller will automatically identify that a new drive has been installed, then it will partition and format that drive automatically and resume the mirroring process.
Sep 20, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Mybook will not power up
hmmm...disconnect it from the computer and see if it is still unhappy at that point.
Oct 11, 2008 | Western Digital MyBook Pro WDG1T5000 500...
External hard drives not recognized by MacBook Pro using SIIG eSATA II 2 Port ExpressCard-M
I am having the same issue wd external drive on my mac book pro and also a seagate
they both work intermediately on a firewire
Jan 17, 2008 | Computers & Internet
Installing Firewire 400 on a Western Digital 500gb external My Book Pro
Don't connect the USB and firewire at the same time, use one or the other. In general for USB, for the very first connection, it is better to have the computer fully booted, and the MyBook spun up, before connecting the USB cable. After that, you can boot the computer with or without the MyBook connected or turned on. For the firewire connection, check your manual for the correct order of connection and power on.
USB and firewire 400 are roughly comparable. USB is theoretically a little faster, but you will see little difference. There are other factors that can affect your actual performance, so your best answer is to try a test yourself. Time a copy of a very large file, and a copy of a folder with a very large number of files.
Dec 03, 2007 | Western Digital MyBook Pro WDG1T5000 500...
Western Digital My Book  Pro Edition  II WDG2TP10000 1 TB FireWire 400 (1394a) Hard Drive Logo
190 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
