Question about HP Office Equipment & Supplies
  • 1,913 Answers
Check your card in card reader it is working properly or not.then ps let me know if u need further assistance.
Posted on Nov 26, 2008
Pdr m700
Hi Lorinda,
There are a few different reasons why your camera may not be reading the memory card.
Troubleshooting such problems can be a little tricky, especially if no error message appears on your camera's screen.
The cause and solution may include one of the following:
    ·The card may not be the right type for the camera: First make sure the memory card you are using is compatible with your camera. For example, a SDHC memory card often will not work with older memory card readers. Even though SD memory cards are similar in size and shape to SDHC cards, they use different software for managing the card's data, meaning older readers sometimes cannot recognize the SDHC cards. Sometimes you can solve this issue by updating the memory card reader's firmware to give it the ability to deal with SDHC cards. Check the Web site of the manufacturer for your memory card reader to see if new firmware is available. It is also a good idea to check with your camera's manufacturer (on it's website) to see if an updated version of your camera's firmware is available.
    ·The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    ·The card or a file on the card may be corrupt. Photo file corruption can occur when the battery power is too low when writing a photo file to the card, or when the memory card is removed while the camera is writing a photo file to the card. One way to check if it is the card or your camera is to try moving the memory card to a computer, then try accessing the photo file directly from the computer to see if the file actually is corrupted, or if your camera is just unable to read a particular file.
    You can also double check this issue by using another memory card in your camera and see if it works as it should. If the memory card is unreadable on any device, the next step is to reformat the memory card. Look through your camera's on-screen menus to find a "format memory card" command. However, keep in mind that formatting the card will erase all photo files stored on it. Some cameras just work better with a memory card when that memory card is formatted inside the camera. If you do reformat the card, make sure to let the process finish itself before removing the card. Removing a card during formatting may damage the card.
May 01, 2014 | Toshiba PDR-3300 Digital Camera
i have had that issue have you tried a different card, if the problem persist there something wrong with the insert dirty or damaged they normal give you a blank one that ant real too keep in there too keep it clean.
Apr 10, 2011 | Computers & Internet
When I insert my SDHC Card into my printer/scanner it gives me an error on card. Putting the card in the camera I can review pictures perfectly, I have a new DMC-ZS5. Any suggestions?
The problem is that your printer is only compatible with SD cards, not SDHC cards. You bought a larger card for your camera, not noticing that it was SDHC (or not knowing that it wouldn't work in the printer). The new card doesn't work, not because it or the printer is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to limit yourself to a 2Gb card, (and be extra sure that it doesn't say "SDHC" on it) or to find a different way to get the photos to the printer.
Feb 21, 2011 | Panasonic Cameras
When I insert a SDHC memory card in printer,I get card access error message.How can I solve this problem?
Your printer was designed to use SD cards with a maximum 2GB capacity. It was not designed to be compatible with SDHC cards and cannot read them.
SDHC cards are a later development and will fit into the same slots, but are technically different. As the difference is due to hardware incompatibility, there is no way to update your printer to accept the later standard.
Jul 09, 2010 | HP Photosmart 375 InkJet Printer
I get a card reader error on my printer when i insert my PNY Micro SD card
Has the card worked before.If it is the first time you have tried,is the SD card an SDHC,as some printers will not read these.Try a standard SD card and see if your printer reads that.Hope this helps.
Apr 12, 2010 | PNY 2GB microSD Memory Card
SD memory card error
Please check if it is not an SDHC (larger than 2Gb) card. Some printers can only read SD (2Gb and smaller) while some can also read SDHC (SD High Capacity) cards.
the C4180 can only read 2Gb and smaller (Standard SD)
Feb 28, 2010 | HP PhotoSmart C4180 All-in-One Color...
Why did printer cause my computer to close when I inserted a 4GB sdhc card into it?
Did you have another card in, the unit can only handle one card at a time.
What do you mean by close, did it blue screen, did windows restart,did it white screen, was there an error code, close does not explain what happened.
The printer can handle 6 different types of cards, one thing, its says
SD Cards, now there is a difference between SD and SDHC, some devices can not read SDHC, high captivity is a different format then a SD card. now maybe the printer can't read the card, but I have no clue why windows would shut own or do anything, because windows can handle any card.
Restart both, and make sure there are no cards in it then try the SDHC card again and post exactly what happens, and errors, if it says anything, this will help you getting your problem solved.
Feb 12, 2010 | HP PhotoSmart 7350 InkJet Printer
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
614 people viewed this question
Ben Johnson
