Question about Maytag Neptune MAH5500B Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
LAST TIME MY WASHER WOULD NOT DRAIN, IT COST ME $80!!!! FOR THE REPAIR MAN TO UNCLOG MY PUMP. 2 WEEKS LATER, SAME PROBLEM. I WANT TO UNCLOG IT MY SELF THIS TIME. HOW DO I TAKE MY WASHER APART TO GET TO THE PUMP?
Siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Posted on Jan 08, 2007
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
Flashing F2
see the details and fix it. God bless you
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
•check the drain filter pumpfor foreign objects
• If the above does not correct the problem replace the pump
Jul 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
LONG DRAIN
NOTES:
4. Check the drain pump filter for foreign objects.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My washer will not drain the water and the spin-Model ATF6000FS1
I had the same problem but bought a new washer. As we were parting this washer out we found that there is a black rubber boot the attaches to the water pump. There is a filter inside of this boot and it was clogged with hair, string, and almost 2 bucks in change. No wonder it wouldnt drain. Check yours and see if thats your problem too!
Oct 05, 2009 | Frigidaire ATF6000ES Front Load Washer
My frigidaire front loader washer will not fully drain water and leave clothes soak and display an E20 code
An e20 error is a slow drain. Basically you have a clogged pump. I just had to unclog one today! Unfortunately they are a little hard to get at. Usually they have a small sock or coin stuck in them. The pump is located in the right back. Good news, no cost to fix, bad it's just going to take some time.
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F-2 Error Code
f2 is long drain so your already on the right track. check and replace drain pump.
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
1,075 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
