Question about HP PSC 2210 All-In-One InkJet Printer
Remove and check cartridge
My HP PSC 2310 printer was working fine and has relatively new cartridges in it (they couldn't be empty yet and the ink flows freely from the printing points) but has suddenly gotten stuck asking me to remove and check cartridges. I have done this several times, cleaned them and replaced them and it just keeps displaying the same error message.
It won't do anything other than this. Please help.
Thank you.
Craig
  • 51 Answers
If you already changed the cartridges for new ones, there should be a problem with the printer's carriage.
You need to take it to a repair store, but I advice you to buy a new one, because the price you will pay for the repair should be the same or more than what you pay for a new printer.
Posted on Nov 28, 2008
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Nov 08, 2010 | HP PSC 2350 All-In-One InkJet Printer
Check and remove ink cartridge
Are you using refilled cartridges? If you are this could be your issue. New cartridges have a chip in them that allow the printer to know when the cartridge is empty, when you refill the cartridge there is no way to reset the chip and can cause this problem when using refilled cartridges.
May 28, 2010 | HP PSC 2110 All-In-One InkJet Printer
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
3. Press the change cartridge button. It is at the top of the printer next to the power button.
4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
Remove and check cartridge in right stall help
Make sure that they are new cartridges.
Also make sure, that you took off the strip off where the ink come out.
Then shut if off, wait 15 min, then turn back on.
Good Luck
Nov 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
I would say you're better off buying a new printer, especially if it's an older one. If it's still newer,see if it's under warranty (less than a year). If you just bought it within 90 days, usually you can return it to the store where you bought it and get it exchanged. Sounds defective to me.
Jun 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printing problems
The light will stay on if the cartridge is not inserted correctly, check if it is in correct if you still have the problem remove both cartridges and insert the both of them back the same time.
Nov 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Remove and check color cartridge
I cleaned mine with alcohol and Q-tip and then shook it 25 times to insure that the ink was penetrating the application lines. My hunch is it first got dirty, and then dried up on the exterior prevent additional ink from leaving the cartridge.
May 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
HP psc check print cartridge light is flashing
The "E" means a cartridge problem.
Have you recently changed them?
If so, did yo use "refills" or another non-HP cartridges?
Jan 11, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 2210 All-In-One InkJet Printer Logo
188 people viewed this question
Seeker5211
Seeker5211
