Question about Altec Lansing ADA 885 Computer Speakers
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Posted on Jan 24, 2009
ALTEC LANSING ADA745 WILL NOT POWER UP
check whether the adapter is fine or not..
that may also be a problem...
Mar 26, 2008 | Audio Players & Recorders
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
How do you connect the altec lansing ada 890 speakers to a flat panel HD TV
You can use the audio output RCA outputs to connect to the speakers. You need to use a multi- connector to match the input of the Altec. You can get the mating connectors to the headphone to RCA which can be connected to the Audio outputs. Also you can use a network to match the input impedance, use a simple reisitive network.
Dec 09, 2011 | Altec Lansing ADA 890 Computer Speakers
Can I hook up Altec Landsing VSA3251 to my TV? the plugs do not seem to be the same
you can hook it up to your tv if you have a 3.5mm headphone output jack on the tv :) any powered speaker can get a signal from that jack. mind you, this is only a stereo signal so if you are running a surround setup 5.1 and up you won't have all the channels for your speakers.
Jun 11, 2011 | Altec Lansing 4100 Computer Speakers
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
Is is possible to install altec lansing speakers
It is possible to hook up these speakers to a laptop according to this brochure:
http://www.alteclansing.com/images/spec/vs4121%20sell%20sheet.pdf
Now this manual shows those speakers being hooked up to a computer but laptops have the same outputs as well so here it is:
http://www.alteclansing.co.uk/images/quick/vs4121qcc.pdf
you'll need adobe reader to read the manuals.
May 17, 2010 | Altec Lansing VS4121 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
412 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
