Question about Asko Washing Machines
Asko W640 - sporadically says motor fault and won't run, or, won't stop running, gets stuck on the spin cycle. We've had the motor fault problem before, but this "running on" issue is new. Also Dryer - T760, we had to undo the heater unit connectors to replace a belt and now the dryer won't warm up to dry clothes. Is their a schematic of the wiring order we could follow?
    Scholar:
  • 111 Answers
I would say the won't-run problem is separate from the run-on problem. You can live with the run-on problem -- probably a fault in the controller. Unless it's a faulty code, the motor-fault light probably means the motor is overheating. That can be caused by anything that causes it to work hard, such as a stuck pump.
Posted on Nov 27, 2008
Had a "wash motor fault" in July 2007, had a
Welcome to FixYa.
This can be associated with worn brushes in the motor or a sign of a damaged spot on the motor armature, hence when you spun the drum off of the dead/damamged part the unit began to operate.
If capable one can remove the rear panel, and with the aid of a flashlight inspect the brushes and armature.
I'm surprised how often I hear of these motors being replaced when in most cases a new set of brushes will remedy the problem...alas I guess there is more profit for technicians for relatively the same amount of work in replacing a motor.
Let me know if the problem re-occurs or if you'd like a service guide into inspecting the components I alluded to.
Thank you.
Regards,
Macmarkus :)
Jan 13, 2011 | Asko W640
Our Maytag Neptune MAH3000 does not advance through the rinse and spin cycles. The problem is sporadic. Sometimes it advances through one or two spin cycles and then stops, sometimes it stops on the first...
Have you cleaned the large drive belt, if it slips it could cause this sort of fault. Motor will stop if it doesn't get a signal from the drum. Just try wiping the drive belt with a damp soapy cloth and then wiping again with a damp non soapy cloth. You will need to remove the back, unplug it from the power before starting any work.
Apr 30, 2017 | Maytag Washing Machines
Violent spin cycle
Did you remove the shipping bolts?
Apr 27, 2009 | Asko W640
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Sep 11, 2008 | Asko W640
Fault indication: water inlet fault
see if there is a blockage in the level switch. the switch operates on air pressure within the dip tube and the diaphragm in the switch. there may be a spider's nest in the tube or a wasp's nest in the tube.
Feb 03, 2008 | Asko W640
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
165 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
