Question about IBM TravelStar 4GN 4.32 GB Hard Drive
HDD keeps clicking
I tried to defrag the hdd. It got to 10% and gave up. All I get out of it is a clicking noise and the start up screen states that the hdd is missing. I have removed the hdd and connected it to an external usb caddy and then to my PC. The drive continues to click and isn't seen by by my PC. Is this this a mechanicle fault and not repairable?
  • Karl Moss Jan 09, 2007
    Many thanks, it was worth a try!
  • 624 Answers
The clicking noise is the sound of the read/write heads going to the home position. The arm or bracket the heads are mounted on make the noise when they hit up against the equivalent of a *door stop*. This is the drives attempt to reorient itself when it can read something where it expects to find it. As you have guessed its probably a mechanical fault and definitely not repairable.
Posted on Jan 08, 2007
HOW OFTEN??Should you defragment?Do I have a HDD or SSD hard drive??How do I find out??Does defraging SSD destroy your hard drive quicker?
If you use a proprietary defrag system like iobit.com, defragging everyday keeps the filing cabinet in good order cutting down on search time and saving wear on the hdd. If you download
Speed Up Slow Computer Keep PC and Internet Secure Freeware Download IObit
It will sort out your SSD or HDD for you automatically. We can only tell the type of drive from the computer information list that we cannot see because it is on your computer.
Mar 26, 2016 | HP Computers & Internet
Faded screen
Sounds like your machine is having trouble keeping up with the tasks you want to perform. Try defragmenting the hdd.
Feb 03, 2014 | Computers & Internet
My hp 550 keeps freezing at the start up screen and it takes several attempts to get it to start up but when it does it works fine. it also starts ok in safe mode
Scandisk. Check HDD for SMART problems. chkdsk. Remove old unused programs. Check MSCONFIG for startup items. Use Ccleaner to clean up your computer. Use Malwarebytes Antimalware for malware removal. Defrag your HDD. You can use Auslogics Disk Defrag Screen Saver. Post results please
Nov 03, 2012 | HP Computers & Internet
I turn on asus laptop and it seems to be can't complete "POST".
r u sure that your comp isnt completing POST coz from the issue stated i suspect that it could be a hdd issue. try doing an OSRI from a bootable disc and this should resolve the issue.., else try running DIAGS on the hdd to check if there is any issue with the HDD.
Mar 03, 2010 | ASUS A6J Notebook
My laptop is so slow and it makes a sound
SPEED UP PC BY DOING FOLLOWING
1.Removed unwanted startup entries and disable unwanted services Start > Run and type "msconfig" Start > Run and type "services.msc" 2.Defragment on regular intervals defrag volume [-a] [-f][-v] [-?] 3.Keep System Restore turned off 4.Disable disk indexing
THE SOUND COULD BE MANY THINGS HDD GETTING OLD OR CPU FAN FAULTY TAKE LAPTOP TO PC REPAIR FOER STANDARD MAINTENANCE CHECK UP
Aug 31, 2009 | Computers & Internet
SYSTEM IS SLOW
Try running a disc cleanup and then defrag. They should be located in your control panel under the maintenance & performance tab. Doing this regularily will help keep your system running smooth. Hope this helps.
Apr 19, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Hdd failure
It is not smart to switch a IDE with a SATA,
it should be IDE with IDE and SATA with SATA
Each transmit diffrent levels of instructions.
The clicking is definitely not a good thing. It means you nearly shorted something out to the point where its not sending the correct impulses in power. Most likely the hard drive might be able to work. but the clicking means its blocked or somethings preventing the head from moving or doing what its supposed to do. You will need a new Hard Drive.
My recommendation is to send your old HDD to have it recovered in a clean room if you want your data from it. or replace board with like board, being exact. other wise switch the board and have a high level format for the clicking. Its the only real way to fix a HDD, but its not worth it for the cost that you will be charged. Your better off buying a new HDD
Aug 09, 2008 | Samsung SpinPoint V80 SV1203N 120 GB...
My computer is extremely slow
1. Uninstall Unneeded Programs (Start, Settings, Control Panel, Add/Remove Programs) Keeps at least 10% of your HDD free, 20% is preferred. Windows uses this space for it's swapfile.
2. Scan Your Hard Disk for Errors. (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
3. Scan for Viruses (If you don't have an updated and functional AV, http://free.grisoft.com)
4. Check for Spyware and Adware (http://www.download.com, Spybot search and destroy)
5. Defragment Your Hard Drive (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
6. Adjust Visual Effects for Better Performance (Right-Click the MY Computer Icon, Properties, Advanced TAB)
7. Stop Programs from starting on Windows boot (Start, RUN, MSCONFIG)
Jun 22, 2008 | Gateway Computers & Internet
My pc is running very slow
Please would you like to be more specific. What is the size of your Hdd and the RAM? What about the processor?
May 23, 2007 | EliteGroup P4M800PRO-M Motherboard
IBM TravelStar 4GN 4.32 GB Hard Drive Logo
182 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
