Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
I replaced the belt on the vaccum cleaner for the brush and it just seems too loose. How do I tighten it? Do you have a diagram I can look at. I lost my instruction booklet.
  • nola1961 Nov 27, 2008
    We've had the Windtunnel appox. 9 years. Always reliable. Last week I tried to vacuum and noticed nothing was being picked up. I had good suction but still had dirt on the floor. I truned the vacuum over and noticed the brush was not spinning. I took off the plate and noticed the V belt was not spinning. It was like it was too loose. I bought a replacement V belt; had no trouble replacing it. But the brush still won't spin. The new V belt seems too loose as well. I tried to push it as far as it would go into the grooves and still nothing. Do I need a new brush?? Or am I missing something??
  • 30 Answers
Are you certain the belt is on the idler arm and that the spring is still in place? The belt has to sit on the small wheel to provide tension on the belt.
Posted on Dec 21, 2008
  • 65 Answers
Try using a smaller belt from a different manufacturer. not to much smaller. you dont want it to be extreamly tight just get one slightly smaller and try that. it dosnt have to be made by hoover. as long as it is not wider or thinner just about the same width and slightly smaller. i do it all the time with my vacuums to save money
Posted on Dec 06, 2008
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Why does Beater Bar Fail to turn
Per owner's manual
1. Make sure the brush control is set on carpet mode.
2. The brush will only spin when the handle is reclined.
Others:
The belt has worn out and needs replaced. Although it appears okay, stretching is possible, which would result in too loose a grip to turn the bar.
If the belt was replaced, it may not have been pulled tight enough to turn the bar. To tighten on many vacuums, simply loosen the screws on each end of the brush, pull toward the front of the power head and hold while tightening the screws.
Jul 25, 2014 | Dyson DC14 All Floors Upright Vacuum...
The spinning brushes on the vaccum no longer spin, how can i fix this? The vaccum picked up a very small wire from a video game and i turned it off immediately. I unwound the wire but the brushes no...
You have either broken the belt or more likely the clutch easiest is to replace cleaner head assembly £75ish or call Dyson and arrange a service if you're not DIY inclined but check belt !st
Oct 31, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I just replaced my hoover belt and it is too loose to make the brush spin. Is there an adjustment to tighten the belt
Greetings from GoVacuum,
The belt is going to be loose as long as the vacuum cleaner is in the upright posistion. If you have the vacuum cleaner with the handle locked in the upright setting, then the belt will be tight around the skinny belt. Once you release the handle of the vacuum cleaner, you can watch as the belt tightens over the roller brush. There are numerous problems with this particular model. We have recorded a very helpful video review of how to replace the belt, and do basic maintenace for this particular model. Hopefully this will help you figure out the correct installation, and other maintenance work you can do yourself.
Here's the video;
If this still does not fix the problem, and the brush is still not spinning, please feel free to email me at chris.jones (at) govacuum.com. I'm always more then happy to try and help you fix the vacuum.
If this information helped you, please click the rate this solution by clicking the thumbs up icons in the right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Apr 23, 2009 | Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Vaccum Cleaner
You can download the manual here and it will tell you how to replace your belt. I could tell you, but I won't have diagrams which the manual does. Let me know if you require more assistance.
Dec 10, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
152 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
