Question about VIA P4MA Motherboard
Configuration of mic controls for VIA VT8235
If I open advanced controls for mic in the audio section of the control panel, two sliding bars for high and low tone setting are showed but not activated (they're grey).
How can I succed in activating them?
My sound card is integrated in the motherboard KuDoz 7X/400A and utilizes VIA Apollo KT400A + VT8235 Chipset
My OS is Win XP
  • 105 Answers
NOT ALL CARD have this functionnality
or some of the files' of the drivers are not more accessible, try to reinstall soundcard drivers
Posted on Nov 26, 2008
How do i get my mic to work on my computer
If you have a speaker icon on your desktop, usually at the bottom Rt, double click on that and a window will open. In the options menu select advanced controls and one of the sections should be for the microphone, make sure its on and at a reasonable volume. You may have a sound control panel in the control panel which allows you to select the input in the audio and speech sections. Some of these also allow you to test the microphone at the same time.
Sep 09, 2014 | Computers & Internet
Open mic??
If you run a windows xp ..try to click the volume icon in task bar (tray ) double click ..and will bring the volume control window In there look under the mic and lower the volume ..or mute it until you use it ..or if it has advanced section on it ..and remove the boost ..
In windows 7 ..just go t control panel and select the sound icon ..and in there select mic ..and advanced and remove the boost or if it does not have it either mute it ..or lower the volume for it ..
Dec 21, 2011 | Acer Aspire Computers & Internet
Change for new mic but not working
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Aug 15, 2011 | Computers & Internet
My mic does not work on my microsoft lx-1000 head set, the audio works through the earpiece but no the mic, i've gone to set up a mic in the windows 7 settings but it does not hear me. I had a...
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Jul 30, 2011 | Computers & Internet
Audio driver is working properly but mic is not working.....using lenovo g430 3000
If the audio driver is working properly but the microphone isn't, ensure that: 1(a). The microphone is not muted.On Windows XP, go to start, run and type sndvol32 and press enter button to launch the Windows Sound Volume Management Panel. Under the Microphone volume control, uncheck "mute" box.This should make your microphone functional again. (b). The wrong microphone may be selected, esp. if your sound-card has an external port for microphones.To rectify the problem, use 1(a) as illustrated above, go to File>Advanced Controls and select Input Devices.Under the Microphone advanced settings, you'll see MIC1 Select and MIC2 Select. Switch the selection as appropriate until it works. 2. If the audio driver has it's own Sound management Panel, e.g that of Realtek, open it's sound control panel and disable all microphone effects that may be enabled. 3. Ensure that sound acceleration is maximum. Open the DirectX Diagnostics Engine by going to Start>Run> and type dxdiag and press enter button.When the window opens, click the Sound tab and slide the Sound acceleration bar to maximum.
I hope my solutions work.Have a good day.
Feb 11, 2011 | Lenovo IdeaPad Y430-3231U Notebook
I have a new Compaq 610 laptop with XP professional. For some reason we can't get the internal microphone to pick up any signal. What can we do to fix it?
wel first of all did you installed the sound card? And after that go to the control panel and sound and audio devices = > click on advanced a new window will pop up click in the left corner on OPTIONS and be sure in properties the mic box is checked and after that go again to OPTIONS and click Advanced options, under de mic level bar you wil have a buton called advanced click`it and Check the box 1 mic boost
Mar 11, 2010 | Computers & Internet
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
I have a compaq presario v3700 with windows xp.It has conexant high definition as audio. I plug in my headset. It works in terms of audio hearing on headset but u can also hear it on computer. Then my...
Don't think its the drivers, because you can hear audio.
Do you have your mic with your headset or separatedly? If with headset, maybe your headset has a physical switch where you can enable/disable mic (seen this feature on some Locitech headsets).
You can also check whether you have Mic muted in your audio control panel. Go to Control Panel, open Sounds and Devices and File - Properties if I remember correctly (sorry, I have Vista now) and put a check before Mic property to bring out the Mic volume level bar to see whether it's muted or not.
Hope this helps,
Nov 17, 2009 | HP Pavilion dv9000z Notebook
I have no sound through my mic when i talk to anybody they say they can hardly hear me
The mic has a volume control in the Control Panel:
[Control Panel]
[Sounds and Audio Devices]
Click on the [Audio] tab
In the "Sound Recording" section, click on [Volume]
Move the volume bar .... well, you know...
Sep 22, 2009 | Gateway M305CRV Notebook
Dell dimension4600. microphone does not work. I have a portable microphone connect to the pink mic connection.
it might be a bad mic or it may be your mic settings
its worth looking into, try connecting a audio source to it when you are configuring it and have the volume control for the microphone (on the playback section) so that you can hear it when it starts working
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
VIA P4MA Motherboard Logo
384 people viewed this question
Top VIA Computers & Internet Experts
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
