Question about Akai LCT2660 26 in. HD-Ready LCD Television
Sound, but no picture?
This tv was given to me by a friend because it was broken, and i want to see if it's fixable. nothing is wrong with the power supply or anything, but when you turn it on, the picture will flicker on for half a second and then disapear. the sound although, stays on. any ideas? -a
  • alex perez Jan 08, 2007
    i dont think that's it. EVERYTHING works perfectly except the picture will not stay on. when its off,the standby light is on and everything. i push the power button, and the light turns green. after a coule of seconds the "no signal" blue screen appears and dissapears immediately. if i plug the cable in, i hear the sounds from the tv channel and can even switch channels. the screen just stays off. any other suggestions?
  • bpet42 Mar 23, 2008
    my akai tv screen went black after a click sound.
LCD inverter (*_~)
Posted on Jan 21, 2009
  • 62 Answers
Video board - call 800-726-4405
Posted on Mar 29, 2008
    Champion:
  • 367 Answers
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Posted on Feb 02, 2008
Check the fuse
Posted on Jan 08, 2007
My sansui television fell off my tv stand, it dropped about a 1ft to 1.5ft on the glass front but didn't break, sounds like it turns on but no picture, do you think its fixable?
You need to give it a shake and see if you hear anything loose.
respond with how this turned out.
Assuming its a CRT, something heave ripped away from the board on impact.
or the nack board on the back broke the tube.
the first situation is fixable, the second is not.
If its a small TV you should forget about it, the charge to fix it won't be worth it.
If you got a techie friend, you got a good chance.
PLEASE RATE THIS ANSWER
Aug 15, 2011 | Sansui Televison & Video
Have NEC LCD 40 inch tv which now has no sound or picture with coloured lines down he screen, is it fixable or has screen given up??
Uh-Oh....Vertical lines, NO PICTURE. That is NOT good.
Did your TV get hit or fall over?
The LCD panel is actually broken.
If you had a picture on it, it would still be a bad LCD panel, but when you get lines and no picture, it means the row/column bus has been severed somewhere.
The downside is the LCD panel will cost the same or more than the TV set.
I wish i could have a better solution.
Let em know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 01, 2011 | NEC 40IN LCDTV 1920X1080 1000:1 40 in. LCD...
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Broken screen
If ur screen is got hit by any object or LCD screen noticeable,broken not worth fixing,because the tv compannies sell the LCD screen same as a new tv.If the tv is normal use video just die.Than replaced ur LCD inverter board to get picture back.
Dec 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture - just sound. What's wrong and is it fixable?
IT IS PROBABLY THE MAIN BOARD THAT HAS FAILED. CALL 1-800-SAMSUNG FOR NEAREST REPAIRCENTER.
Nov 16, 2009 | Samsung TXM3297HF 32" TV
Our tv comes on but has NOTHING on the screen, it
If your able to hear sound but theres no picture its usually from the fluorescent lamps being broken or the power source that lights them up are broken.
Oct 26, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Broken Hard drive. Is That fixable
Broken HD is more likely to be broken and not fixable. However if it's under warranty try contacting the name of the HD and let them know that it's not working anymore.
They can fix the disc or componant that's having a problem. There's nothing much you can do except the manuafacturer that can own it. :))))
Sep 07, 2009 | EverFocus EDSR400H Video Recorder
Sound but no picture
yes the tv is fixable an estimated cost is about $40.00 to a $200.00.the problem is in the video circuit.
Apr 01, 2007 | RCA F32632SB 32" TV
Akai LCT2660 26 in. HD-Ready LCD Television Logo
210 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
