Question about HP Computers & Internet
Monitor is in sleep mode and I here a beep periodically
1) do not know command to take off of sleep and keyboard does not have sleep button
2) beep gives impression something is stuck but have shut down with no fix
  • 153 Answers
Try change the keyboard, if the pc does not detect the keyboard or a key from the key board is stuck which gives something like tic tic sound. On the other hand the display from monitor "sleeping mode" indicates the VGA cord is faulty or monitor is no compatible to the PC's video card.
Posted on Nov 27, 2008
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Tip
UnLocking Sleep and Lock Modes for Pride and Invacare power chairs
<p><b><span>Pride Joysticks and others that use VSI joysticks</SPAN></B><br><p><b><span>SLEEP MODE</SPAN></B><br><p><span>Your VSI controller has a sleep mode feature. Sleep mode is a built-in circuit </SPAN><span>that automatically shuts off the main power if the joystick is not moved </SPAN><span>in any direction for a period of time predetermined by controller program.</SPAN><br><p><span><b>The battery condition meter lights on the keypad indicate sleep mode by </b></SPAN><span><b>blinking once every five seconds.</b> To restore power and continue, push the </SPAN><span>on/off key twice.</SPAN><br><p><span> </SPAN><br><p><b><span>Lock Mode</SPAN></B><br><p><b><span>To unlock the VSI:</SPAN></B><br><p><span>1. Press the on/off key and power on the VSI. <b>The maximum speed/profile </b></SPAN><span><b>indicator should ripple side to side</b>.</SPAN><br><p><span>2. Push the joystick to the full forward position until the VSI beeps.</SPAN><br><p><span>3. Pull the joystick to the full rearward position until the VSI beeps.</SPAN><br><p><span>4. Release the joystick. There should be a long beep.</SPAN><br><p><span>5. The VSI is now unlocked.</SPAN><br><p><span> </SPAN><br><p><i><span>Invacare and others that use SPJ+ joysticks</SPAN></I><br><p><i><span></SPAN></I><i><span>FOR SPJ+ Joysticks</SPAN></I><br><p><i><span><b>Lock Mode will be indicated by all LEDs</b></SPAN></I><br><p><i><span><b>flashing briefly and the information gauge</b></SPAN></I><br><p><i><span><b>LEDs chasing slowly from right to left</b>. If</SPAN></I><br><p><i><span>this occurs, press the horn button two times</SPAN></I><br><p><i><span>within ten seconds to unlock the joystick.</SPAN></I><span></SPAN>
on Nov 16, 2010 | Health & Beauty
I accidently hit the sleep button on my keyboard (Viewmate CC2201) and my monitor went blank and I dont know how to get it out of sleep mode. Help !!!!!!!!!!!!!!
Press, but do not hold, the power button one time. the system should start back up and resume windows just as you left it.
GOOD LUCK AND PLS RATE THIS POST!!!!
Nov 16, 2010 | ViewSonic (CC2201) Keyboard
My monitor will not stay on, it goes on sleep mode
Your problem may be due to the sleep button in your keyboard may got struct into when you cleaned your keyboard.
Try to resolve the struct in the keys, if any.
Restart your system and if still your problem persists, then remove your keyboard and restart your computer and try with some other keyboard if possible. Once if you find out that the problem is with your keyboard, then replace the keyboard / service the existing one.'
I hope this is helpful to you. Please provide your ratings.
Thanks
Apr 05, 2010 | E-Machines eMachines Monitor E15T4
Ipod in sleep mode
How to Enable Sleep Mode :
1. Access the main menu on your iPod
2. Go to the extras menu > clock
3. Select your current time ensuring that your timezone settings are correct
4. Select the Sleep Timer options
5. Select the time that you want your iPod to shut down
And if your iPod goes into Deep Sleep Mode then here is the answer to that :
Right "Deep Sleep" is a battery saving mode if the iPod is not touched in say a 18-24 hour period I think. It reboots (resets) coming out of this mode.
1) There are people reporting that they must always reset their iPod to turn it back on after shutting it off, they don't really mention deep sleep at all, search for "must always reset" or something along those lines
2) I'm not sure if this is documented anywhere specifically. It is a normal function of the iPod that we discovered somewhere along the line. Not sure where the first talk about it came from, you may find information on this searching "deep sleep" there was a hack to force the iPod immediately into deep sleep once upon a time.
3) Not exactly. If an iPod has gone into deep sleep, plugging it into the power will automatically start the reboot. In the case of buttons you should be able to touch a button and it will start to reboot, I have found with my 3G iPod it takes a very deliberate touch or two or three touches to the touch sensitive buttons to get it to wake up, but you shouldn't HAVE to do the reset command (i.e. menu/select button held down), if you do you may be looking at more of the original problemin #1
Sep 19, 2009 | Apple iPod touch
Curious - What is the moon shaped key all about
this button puts the computer into sleep mode.
FROM WIKIPEDIA-
Sleep mode can go by many different names, including Stand By (Microsoft Windows 95-Server 2003), Sleep (Mac OS 8)-(Mac OS X) / (Windows Vista,Windows Server 2008), and Suspend (Linux). When placed in this Sleep mode, aside from the RAM which is required to restore the machine's state, the computer attempts to cut power to all unneeded parts of the machine. Because of the large power savings, most laptops automatically enter this mode when the computer is running on batteries and the lid is closed.
Though Sleep and Hibernate are generally thought as two separate functions, modern Macintoshes, Windows Vista (termed Hybrid Sleep), and some specially configured Linux machines also feature a variation of Sleep mode that incorporates the strengths of Hibernate. The RAM is copied to the hard drive before sleep mode is initiated, preserving the RAM contents in the event of a power loss.
ACPI is the current standard for power management, superseding APM and providing the backbone for sleep and hibernation on modern computers. Sleep mode corresponds to ACPI mode S3. When a non-ACPI device is plugged in, Windows will sometimes disable stand-by functionality for the whole operating system. Without ACPI functionality, as seen on older hardware, sleep mode is usually restricted to turning off the monitor and spinning down the hard drive.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 04, 2009 | HP Computers & Internet
Monitor going to sleep
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Computer will not go into sleep mode
External drives (hard drive, DVD burner, iPod, USB drive), printer, a worn out mouse button, debris in/on the keyboard, and cats are all things that can cause your computer to refuse to sleep (or wake it shortly thereafter).  Rule out these first.  I have had the same problem in the past.  It is almost always one of these that causes the problem.
Feb 23, 2009 | Apple Power Mac G4 Desktop
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
304 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
