Question about Hitachi 51SWX20B 51" Rear Projection Television
Sound but no pic
We can get the sound to come on only a scratchy sound but not a picture of any type. my center board has 3 green lights and 1 red one . is this norm or is that telling me were the problem is?
  • john forgette Jan 25, 2007
    i still need help with this please
    you can send info to changyrlife@sbcglobal.net
    Sergeant:
  • 308 Answers
This is a projection style TV with a removable light box which makes it easier to service. You could have a defective flyback (high voltage) transformer, or a leaky zener diode in the voltage regulation circuits as well. Depending on how old the set is and how the picture quality was before going out, will dictate the feasability of getting it repaired. My guess would be over $300 and possibly close to $500 if the flyback needs replacing.
Posted on Jan 27, 2007
    Problem Solver:
  • 12 Answers
Does the projection lamp turn on, look in the back it should be visible. If not I would replace this and maybe the ballast first. If this still doesnt resolve the issue then the whole Optical engine might need replacement.
Posted on Jan 26, 2007
When I turn on the TV the green light goes green to red to green to red. If I keep turning it on and off eventually I get a picture. The picture is very dark at first
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 26, 2015 | Akai Televison & Video
I turn on the tv, indicator light flashes green, I hear a intermittent hissing type of sound coming from the back of tv, sort of like a loud scratchy hard drive, the sound repeats 3 times then the...
The fault is with its mother board [main board]. SCL-SDA line short. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Sony KDF-E42A10 42 in. LCD Television
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
HELP! Can you help me Slinte?
Can you post the board location number of thr resistor that is circled in yellow such as R8006 and I will post the rating of that resistor as thats what the problem is usually one or two of the resistors will burn when the ICs go out.
May 10, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
62 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
