Question about Panasonic KX-TG5421 Cordless Phone
Phone Is Not Working
My Home Phone Says Refer to manual to prepare base. Then press and theres this ok button.. Also i cant do anything else cant go on menu or anything Please Help!!
4 Suggested Answers
  • 17 Answers
SOURCE: handset not working after dropping phone
open the phone the transistors mit have got wont charge u much...
Posted on Nov 24, 2007
  • 106 Answers
SOURCE: installing a new base unit
You will need to press the page/locator button and hold it down until the charge light flashes. Once you do this, go to the handset and push OK. It should register as handset 4. Hope that helps. CG
Posted on May 26, 2008
  • 337 Answers
SOURCE: phone says no link to base phone stop working
Try unplugging the base unit and plugging it back in again. This is not guaranteed to help but has worked in the past.
Posted on Feb 28, 2010
SOURCE: Panasonic KX-TGA560B registration to base.
Did you figure this out? I can't connect my phone to base either there is no ok button
Posted on Feb 05, 2011
0 characters
1 Points
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
2 {V}/{^}: "Initial setting"
3 {V}/{^}: "Registration"
4 {V}/{^}: "HS registration"
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
See (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Phones
Tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Nov 08, 2008 | Uniden Cordless Phone
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Installing a new base unit
May 17, 2008 | Panasonic KX-TG5632 Phone
Phone issues.
1st) you must identify the ranking order of your handsets. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset. Go to the main base cradle. On the bottom, where it says "locator" press the "select" button until you get the desired phone rank needed. H1,H2,H3 etc... Then, press and hold the "call" button, under "intercom". (The charging light should start flashing) Now, go to your handset and press the "OK" button on the top upper right corner. At this point, your phone should be working!
If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support. PS: your handset may show model KX-560B, but your main cradle base will show the actual phone model listed as KX-TG5633
Mar 14, 2008 | Panasonic KX-TG5633B Phone
Binatone vempero 4210 cordless phone
press ok button ..>> TAM
press down botton three times ..>> REGISTER
PRESS OK button .....>>PIN CODE
press and hold the page button on the base unit
green light will light up
if this is successful the lcd will show >>SUCCESS
FAILED it will show>>BS SEARCH
If Failed just repeat a few times and it sould work...........
Dec 19, 2007 | Phones
Panasonic KX-TG5421 Cordless Phone Logo
15 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
