Copy a driver AND its exact settings from one computer to another
I have a Océ TDS-860 plotter. One windows XP machine will print PDF files to the plotter in A0 with the driver and all of the other XP clients will not. The Windows 2000 machines work fine. There are no real differences between the XP machines and I've ruled out any permissions problems by switching user accounts etc.
We have a Novell server but I dont think that it is causing this as I switched the machines to use TCP/IP direct to the print server for the plotter and it did not work either. So, I'm pretty sure it's nothing to do with Novell. The working one was on our Windows Server 2003 domain and the other was off the domain. I placed the XP machine that did not work onto the domain. Then I logged on with my own user account. Nothing changed. They are both on Service pack 2. They are both using the same AutoCad service pack 2. Both machines were installed the same way with the same settings.
I want to try and copy the driver with the exact same settings to the other computer and see if that works.
Any other suggestions are welcome.
  • 43 Answers
I found a way to copy the driver settings but it did not fix the problem. I copied the driver settings using the following method;
Press the start menu button and click on run, Then type in the following (Caps Locks actually matter in these commands... surprisingly.):
RUNDLL32 PRINTUI.DLL,PrintUIEntry /Ss /n "printer" /a "file.dat"
where "printer" is the name of the printer in the control panel and "file.dat" is the name of the file you want to store the settings in. for example:
RUNDLL32 PRINTUI.DLL,PrintUIEntry /Ss /n "HP LaserJet 5000n" /a "C:\printer_settings\HP_LaserJet.dat"
Then copy the file from the location you stored it in (in this example it would be the HP_LaserJet.dat in the folder "C:\printer_settings\") to the other computer you want to use it on.
Place the .dat file in a folder on the C: drive of the new computer (for example "C:\printer_settings\".
You need to install the same driver for the printer that is installed on the old PC onto the new PC. Also, remember to give the printer the same name.
Then go to the start menu and then open run again. Then enter the following command:
RUNDLL32 PRINTUI.DLL,PrintUI /Sr /n "printer" /a "file.dat"
Once again "printer" is the printer name in the control panel that you want to copy the settings from and "file.dat" is the file that we are going to copy the settings from this time. So, if you copied the file "HP_LaserJet.dat" from the original computer in our example to the directory "C:\printer_settings\" on the new computer, then the command would look like this:
RUNDLL32 PRINTUI.DLL,PrintUI /Sr /n "HP LaserJet 5000n" /a "C:\printer_settings\HP_LaserJet.dat"
It should now copy the settings from the file to the printer driver.
The actual cause of the problem was the printer port. I uninstalled the driver and then removed the port that it was connecting to. Then I recreated the port and installed the printer with the previous driver that was still on the machine.
Posted on Nov 27, 2008
  • SpideRaY
    SpideRaY Mar 06, 2011
    Also checkout doing this with an autoit script here
    http://www.autoitscript.com/forum/topic/...
  • SpideRaY
    Then use the Microsoft Printer Migration tool v3.1 to backup all your ports and drivers into one simple cabinet file.
Processes but won't print
Sometimes a plotter will show that is receiving data from the computer but will not print. I assume this is what you are describing. This can be caused by a couple of things. The first suspect is a corrupt file. Try a smaller file to see if it will print. If it does, the problematic files are probably from Photoshop or a CAD program. If a file has more than one level when it is sent to the plotter, the plotter has a hard time digesting it. Try "flattening" the file (makes a single level) and then send it to the plotter.
Another possibility is that the printer driver is no longer matched to the computer operating system or is simply corrupt. Go to HP.com and get the latest driver for the plotter. Windows XP Pro 64 drivers work well with W7 and 8.
Lastly, the Jetdirect card could be faulty. Reseat or replace the card.
Jul 09, 2014 | HP DesignJet 1050c plus InkJet Printer
Print jobs print as portrait and not landscape
you need to change the print settings in the program where you are printing, when you go to print settings the option should be in the dialog box where you choose the printer and page amount.
Mar 02, 2011 | HP Designjet Z6100 InkJet Printer
Our 450C plotter is connected via E-Net Hub and has extened memory. The "Test Printer" works. However it will not complete an Auto Cad Drawing. The ready light continues to flash but the plotter stops. any...
This could be one of a number of things. The file being sent must be smaller than the total memory of the printer. Connect the computer directly to the plotter with a parallel printer cable and see if it prints. If you are using an OS newer than XP, try using the XP 32 bit driver. If you are printing from AutoCad 14 or older, upgrade AutoCad (newer uses Windows printer drivers). If you can print OK with the parallel cable, get new external JetDirect software from the HP website.
Jan 15, 2010 | HP DesignJet 450c InkJet Printer
Copy/pasted jpg shows up in print preview but will
I have had similar issues.
What I found works is open a new window and copy paste it into that.
Or close program and reopen sometimes the printer can not read properly so you need to close and open the file again..
Regards Craig
Feb 13, 2018 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Nec superscript 860 printer driver
Hi Richard,
As you might all ready know, this printer is not supported by Vista,  pasible solution: - if you have another "old" computer, you could install your printer on that, and share it, that way you can printe via the other computer. in case you want drivers for all other software, here is the link.
regards /Teis
Jan 07, 2009 | NEC SuperScript 860 Laser Printer
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Feb 20, 2008 | HP DesignJet 450c InkJet Printer
4,857 people viewed this question
jasbo
jasbo
