EWF TV ANT IN BOKEN
I have a emerson tv that is only 10 months old and my husband tripped over the cable wire, the ant in on the back of the tv broke off (where you hook the cable wire). I looked inside of the tv and I have the piece and the little wire portion off it that broke off where it soders in to the tv. Could I soder the piece back together and back into place or is there a replacement part I could order. I have the same EWF2006 Emerson Television with the ANT IN cable connector broken, but the whole board inside is cracked. I will need to replace that whole peice, but I don't know what name to find or order it under
  • 106 Answers
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Posted on Nov 26, 2008
Need to know how to hook up the dinosaur nintendo
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2010 | Nintendo NES Console
No signal -Samsung HC-R4755
Well Dave have a tech come out and solder your ANT1 connection back on its a simple job that will probably set you back $50.00 or less.
May 31, 2010 | Samsung HC-R4755W 47" HDTV
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
Samsung Ant 1 (Air) and Ant 2 (Cable)
no ant 1 is for dtv off air siginals ant 2 is for cable chann.
Feb 04, 2010 | Samsung DLP HL-P5663W 56" TV
TV ANT Jack Broke off and lost cable viewing
Yes it can be replace only if it just a connector adapter connected independently unto tv tuner. But if it is with the tv tuner as a whole. You will replace the entire tv tuner. Just bring the part as reference to your favorite electronic store selling tv parts.
Apr 11, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Help
Hi and welcome to FixYa,
Offhand, the easiest connection method would be to use a short RF patchcord to connect the RF out of the DVD/VCR to the ANT/CABLE/RF IN of the TV. Set the TV to Channel 3. To continue able to receive ant/cable channels, the cable input should go to the ANT/CABLE/RF IN of the VCR/DVD.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Sharp 27R-S50 27" TV
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
