Question about Sanyo HT30744 TV
On and off picture and color weak Sanyo HT30744
My Sanyo HT30744 has always had a slow start up before picture came on. Now, the power light comes on,warms up, has sound but no picture. For a couple of minutes or so the picture flickers on then off about 3-4 minutes with sound working until it appears to be working with a stabile picture screen. Picture color seems weak however. There has been no adjustment with the color controls. Sometimes a bright color picture other times weak colors. Once the picture stabilizes and stays on it sometimes flickers throughout the day but very briefly. TV in on almost constantly daily 15-20 hours.
  • 1 more comment
  • Anonymous Mar 28, 2008
    tv blinks (off and on)...all other operations are perfect tv is in shop but technition cannot get schematic from Sanyo. no tv is a good deal if you can't get it fixed.
  • seedz2 Aug 08, 2008
    Same Problem, sound, but no picture. Picture comes on randomly for a few minutes, then goes black again. I have had it for about 4 years. Is there any fix, or am I just out of luck? Thanks.
  • dmrotek Aug 29, 2008
    I have the same problem with my TV.  The picture has now completely gone while I still have sound.
    Dale
  • 3 Answers
I'll weigh in here with my problem and how I fixed it. My Sanyo HT30744 had a fluctuating picture. In random order, it would go from bright red to bright green, then sometimes the picture would be very weak and fuzzy/unclear. Sometimes after an hour or so, the picture would become perfectly clear again. Over time the TV got worse, until it almost never became clear again. We only turned it on to listen to the news on occasion. Eventually I decided to take it apart and see if there was anything obviously wrong with it. When I opened it up, the first thing I noticed was how dusty it was. From previous problems with my computer, I remembered that just blowing off the dust (or carefully vacuuming it off) would fix the computer display/operation. So I tried it with this TV.......and now it works perfectly fine. My theory is this: with circuit boards being manufactured with circuits placed so close together, it's just a matter of time before dust begins to accumulate and eventually creates a "bridge" or short across nearby circuits. Essentially the accumulated dust (regardless of how poor of a conductor it may be) provides enough of a connection across the wrong circuits that it disrupts the operation. I have vacuumed out my computer motherboard, power supply, etc numerous times when it starts acting up and it has never failed to fix the problem. So I tried it with this TV and that did the trick too! It's easy to remove the black cover behind the screen. It's just 8 or 10 screws (don't forget the 2 little screws around the cable/coax input). Then carefully slide back the cover. Once you pull it back far enough you can disconnect anything that is tied to it (there wasn't anything on mine except for a zip tie holding a cable), then move it out of the way. Then you can slide out the bottom circuit board so you can clean it. It's very easy to do, just be careful, gentle and be sure to ground yourself before touching any circuits. If you live in a dusty environment or notice a lot of dust building up around the air vents on the black cover, this could be your problem. You really don't have much to lose. You just might fix it for no cost! Good luck!
Posted on Feb 12, 2011
    Problem Solver:
  • 11 Answers
I had the same problem with my refurbished HT-30744 model and my mom's HT-32744 model. It was either try to fix it or buy a new one, so I figred had nothing to lose.
I removed the back cover, unseated the picture tube driver board from the neck of the picture tube (it just pulls off), put on a dab of di-electric grease on the connector on the card, reseated the card, removed and re-applied more grease, reseated the card and the picture has like new for 2 weeks now!
This was a very easy fix.
Posted on Mar 04, 2010
  • Anthony Butcher Mar 05, 2010
    I too had the same problem where my HT30744 TV would lose its color. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
    So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
    Novelist:
    Champion:
  • 236 Answers
I agree with henlopen. Also you could have a loose filiament connection on you picture tube. Also any connection on the picture tube driver board mounted on the neck of the picture tube. AN LCD tv would be a good idea since you watch yours so much. Stargazer
Posted on Jan 28, 2007
    Sergeant:
  • 308 Answers
It sounds like you may have a voltage regulator problem on top of a weak picture tube. For a set that is to be played as much as yours, I would replace it with a LCD model made by Toshiba, JVC or Samsung. My own experience in the field suggests that these are the most "hardy" of the crop of sets now out there today. I would stay far, far away from the Philips, Vizio, Westinghouse, and Zenith sets.
Posted on Jan 27, 2007
Got it new at Walmart in 2006? Never had any problems with it, and always had a surge protector. I know the kids have abused it though. Anyway, yesterday they had a pink, washed screen, turned it off/on...
No.The tv video board have dead components,that the board where it is connected to the CRT-(tv picture tube).Troubleshooting that video board and changes parts should fix ur tv problems.Hope ur tv problems,it is not the video board main big IC colors processor inverter.This big IC is a pain to change and probally not in the market anymore.Troubleshoot test all the capacitors around that big IC colors processor inverter alot of times just those few capacitors are dead only.
Apr 02, 2011 | Sanyo HT30744 TV
How to fix blurry picture on sanyo ht30744
Turn tv on picture is clear and sharp. no problems at all. However, after 30 or 60 seconds picture is blurry, color is distored. stays that way
Dec 31, 2010 | Sanyo HT30744 TV
My color started fading about 2 months ago NOW it its smearing and ghosting.I can turn it off and for a few minutes the pics fine and then its back to the same situation
I had a similar problem. Poor picture quality, and colors way out of balance. The problem: too much dust on the circuit board. I opened it up (remove 8-10 screws and don't forget the 2 little ones holding the coax/cable connection), gently vacuumed off the circuit boards (the bottom one and the one on the back of the tube). It works perfectly now, without ever repeating the problem. This may need to be done every few years, especially in dusty environments. It has also worked on my computer motherboard, and power supply. I think a build up of dust can cause a very weak short across the closely spaced circuits. Give it a try, it's free and you don't have anything to lose! Just be gentle.
Nov 29, 2010 | Sanyo HT30744 TV
My vizon will not turn on and the fuse is ok?i paid alot of money for that tv and only had for4 yrs whats up sanyo?i thiugh you made better tvs than that
Ur power light LED indicator blink?Ur power supply board is dead.Replaced this power supply board will solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 24, 2010 | Sanyo HT30744 TV
Green screen
Not really sure how much the tv weighs, but I know it is a bunch. I have 2 of these t.v.s. One I bought at Wal-mart and after about 6 months it started doing this green screen also. I would normally give the side of the tv a good wack and it would go back to normal for awhile. The other tv I bought from my neighbor who was moving for $25. The problem with this one was the "no picture but I have sound". If I wacked this one I could get the picture to come back on for a while, but it would go out again. Well just the other day I took the back off the "no picture" tv and was looking around. I noticed that the circuit board that is attached to the picture tube was loose. I pushed it back down on the tube and put it back together and the picture has been fine since. So I thought I would check the one with "green screen" issues and sure enough that circuit board was loose also. Pushed that one all the way back down and have not had any issues with that tv either. Hopefully that fixed my problem, I guess time will tell. Maybe it will fix yours also.
May 19, 2008 | Sanyo HT30744 TV
Sanyo remote control hdtv ht30744
You need the original factory remote control. Do a web search for Sanyo. Go to their tech support. They can advise you about how to order a new remote for your set.
Jerry G.
May 04, 2008 | Sanyo HT30744 TV
Green screen
Open it up and check to see it the circuit board attached to the tube is seated all the way down. Both of mine were not attached that well so I pushed them back down and have not had any problems since.
Nov 07, 2007 | Sanyo HT30744 TV
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
My picture is tinted green.
could be that you have speakers around the tv check to see if that is so. and remove the speakers.good luck.
May 18, 2007 | Sanyo HT30744 TV
No Red Color
Just 'cos one Sanyo has started to act funny does not mean all Sanyo TVs are bad. As for the defective Sanyo TV, it seems that there is some problem with the Red Output circuits. Get a professional Technician to have a look. Nothing much you can do unless you know Solid State electronics.
Sep 11, 2006 | Sanyo HT30744 TV
Open Questions:
Sanyo HT30744 TV Logo
551 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
