Hi i have a 32inc tv that was give to to about two mouths ago it has worked grand but lately when looking at it, keep turning green you would be alright for 15mins and then green if you turn it of and put it back on again it grand but other times it takes a bit to get the coulor back any help on price to get it fixed would be good i was told i should bye a new tv but i love this one
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
  • 4402 Answers
SOURCE: No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at Use the Part or Accessory Number to locate the part.
Posted on Jan 17, 2008
  • 41 Answers
SOURCE: stanby light blinks 5 times
The sight in Jean's posting could help. Usually 5 blinks signify that the voltage is too low so you may actually have to turn the knobs up then back them off just until the retrace lines disappear. If one color dominates and you see retrace lines, you may want to turn that one down. But if the dominating color doesn't show retrace lines the other 2 might need to be increased slightly. If you Google Sony TV flashing led codes most likely you will come across an explanation of the codes. Hope this helps.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present in some areas and they can reside even when the set is unplugged.
Posted on Mar 14, 2009
  • 195 Answers
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Posted on Oct 10, 2009
  • 8617 Answers
SOURCE: Got the tv stanby Working
The ribbon connector which goes from the FMT to the DM is disconnected or not seated properly thats the only thing that will cause the 4 4 error other than a broken ribbon socket
Posted on Nov 26, 2009
Testimonial: "ty"
  • 295 Answers
SOURCE: Sony LCD Grand Wega 55in keeps turning off then
Have you ever tried to clean the air intake filter that sits behind your speaker grill. Have you ever replaced your lamp before either?
A/V Media Tech Guy
Posted on Dec 20, 2009
I repaired heater door blend but I don't know how to caliberat the soul climate system jeep grand Cherokee 2003
No problem! First acquir four similar thermometers, second tape thermometers on a doors, turn swith on with keeping egg in you mouth. Turn heater on and wait so long that egg in you mouth is hot and then look what thermometers look. If everyone looks same no need calibrate.
Oct 23, 2012 | Cars & Trucks
I have a KDP 57XBR2 my screen goes solid blue and the tv turns completely off. Upon restart the red led blinks six (6) times. What gives?
Power supply board just die.It can be dead at anytimes.Tries websites, to buy a refurbish power supply board for the replacement.
Hope this help in solving the problem.....
Nov 04, 2010 | Sony Grand WEGA KDP-57XBR2 57" Rear...
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
