Question about Amana Kitchen Ranges
I am havig a problem with the oven itself. The burners are working, but the oven will not get hot. I was trying the self cleaner maybe a week ago. When I tried to use the oven after that it would not get hot. I have never had a self cleaning oven and do not know what is going on. Please tell me where to lite the pilot in the oven.
  • grownnsexy40 Nov 27, 2008
    Thanks for the response, but where do I find the glow bar ignitor. Thanking you in advance.
    President:
  • Amana Master
  • 2,651 Answers
There is no pilot to lite. theres a glow bar style ignitor.the only thing you can do is check for power to the ignitor.and repalceif needed
Posted on Nov 27, 2008
  • Ron Coons
    Ron Coons Nov 28, 2008
    itsmounted to the burner bar under the oven bottom, past number 12400035, comes with all parts and instuctions to install
How do I replace the receptacle for the heating elements on the stove top.
Typically the light is a function of the selector so as long the position of the knob is to the on position it will be on. in order for the burners to work you'll have to replace the connectors, so full current can go through them. also the self cleaning feature refers to the oven meaning you can lock it, turn it to clean and it will get so hot that the build up on the inside will get flaky and then you can clean it once it cools off. I've never seen one that work that well, but it has nothing to do with the glass there is cleaners that you can "rub" kind of like waxing a car and if you have build up on the glass or burned food you can scrape it with a razor laying flat on the glass and scrape the cleaner around will eventually it will peel off.
Jan 14, 2015 | Kenmore Ovens
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
I have a RCA gas self cleaning oven,It heats on broil but not on bake.we have noticed over the weeks the oven was getting as hot as the thermostat was set at.Now it won't heat at all
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 13, 2010 | GE Ovens
My oven won't heat
First you will need to verify if the igniter is coming on for the oven burner when the oven is turned on. You will need to remove the oven bottom cover. There is usually two screws at the back bottom of the oven compartment that holds the bottom on. If there are no screws then it should just lift out. You may need to slide the bottom away from you then lift from the back. You will need to remove the oven racks to make enough room to lif the bottom out. Once removed you should be able to see the burner(you may also need to remove a heat spreader on the burner). Now turn on the oven and watch for the hot surface igniter to start to glow. If it does then you will need to make sure the gas orfice and venturri for the burner are not plugged with debris. You can use a small can of compressed air to try and dislodge any debris. Then give the oven gas valve a light tap with a screwdriver or a wrench. Oven gas valve is usually located at the bottom of the oven. Remove the bottom storage compartment to reach it. If you tap it and the burner comes on there may have just been debris in the valve and you may have cleared it. Then turn the oven off and back on completely several times. If the burner comes back on you should be ok if it does not then it could be a weak hot surface igniter or a bad olven gas control valve. Now going back to the start if the igniter does not come on you will need to verify if the igniter is getting voltage. If it is then test the igniter with a ohm meter. The reading should usually be between 500 to 700 ohms. A common problem with hot surface igniters is that they will crack. Examine the igniter for any visible cracks. If the igniter is not getting voltage then you will need to verify that all wires are properly connected and none have come loose. Look for any melted wires from the self cleaning process. You may need to dis-assemble the back of the range to see if any wires have come loose or melted. Now I need to stress to you that safety is important. Be very careful performing these procedures. You can get shocked or possible burned.
Oct 06, 2009 | GE Spectra JGBP35 Gas Kitchen Range
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Oven Burner
try this,when you see the ignitor glow use a match and try to light the burner itself BE CAREFUL!! if the burner lights the problem is its clogged or low gas pressure.remove the burner and use brake cleaner to clean the burner AND pilot.if your using propane youll have to do this occasionally.let me know.
Jan 04, 2008 | Ovens
Kitchen Ranges Logo
111 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
