Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Engine turns over but won't start
I have gas in tank. The air filter and fuel filter have been changed. Plenty of juice from the battery. Oil in the crank.
Is there a chance the engine could be seized? When I turn the key it turns over but won't catch to start.
  • 22 Answers
Your starter bendix is bad
a common problem
any small engine shop will have a new one
Posted on Nov 27, 2008
Have a 2011 Kubota L3800 that has only 90 hours. Went and started it up today, it ran for about two minutes and died. Any ideas?
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling
  2. Is there a cut off valve at the gas tank?If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look at least 1/2 full of fuel.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
    Do your self a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank.Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started.I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger.Once you have a good fuel flow out the line to the filter, put on a FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  4. Check the fuel pump.The fuel pump system on the twin Koehler and the Twin Briggs (and others) are almost identical. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . https://www.youtube.com/watch?v=HAUZUPoopSI
  5. Note: My engine was starting hard and dying in the field this year (March 2015).While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump.It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  6. Many systems have a fuel shut off solenoid. This is a small cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on. If it does not click you will have to replace it or track down an electrical problem.
  7. If this has not solved the problem you may have to remove and disassemble, clean, or rebuild the carburetor at this point.You may have water, dried fuel (varnish) or trash in the carburetor bowl.Before removing and disassembling the carburetor try draining the bowl.Or, take the bowl off, careful not to drop the small parts inside.Clean the bowl and replace.I often remove the bowl on small engines and save the hassle of a complete carb removal.
NOTE: Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info and I will walk you through the next step.Tracking down a spark problem; yes, your problem could involve the coil. (Not as likely as fuel)
Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
Apr 06, 2015 | Kubota Garden
When you start engine you have to give it gas or it won't start
replace your fuel & air filters, add some fuel injector cleaner to gas tank, todays fuel w/ ethanol is hurting your engine, change your oil also.
Mar 01, 2013 | 2003 Chevrolet Impala
Sugar in a gas Tank
no you have to drop your gas tank clean it out. if you didn't start then just clean gas lines. if you started it then you need a new engine. the sugar gets in the engine and turns to syrup. bad engine.
Jan 28, 2013 | Ford Cars & Trucks
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
My 94 blazer has been stored and not started for a while now it wont start what should i try first it seems to not be firing and cant smell any gas
Turn on your lights- If their bright then you have juice in the battery.
How old is your fuel? Did you use fuel stabilizer?
Is the truck turning over? If not, lightly tap your starter it may be sticking. Then try to start it again.
If its turning over check for spark in the wires.
Check to see how bad your plugs are, pop them out. You may need some new ones.
Sep 23, 2011 | Chevrolet Blazer Cars & Trucks
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Engine tries to crack but will not fire up.
if its a efi there are sensor like the cam and crank that tell the comp to send fuel if any of these are bad it will not start
Aug 17, 2009 | Eagle Summit Cars & Trucks
CBMW wont start will run if push started. Plenty
There are 3 fuel filters in he 528 and when you turn on the ignition, you should hear a buzz that means that the engine is being primed, if you don't, your pump hased gone, The Bms' have a system where the fuel is automatically drained back into the tank and automatically primed prior to starting the engine. This only takes miliseconds, but the primer part of the pump is not part of the mechanical pump so tahts' why it will start when pushed Let me know how you get on. Dave
Jun 09, 2009 | 2008 BMW 528i Sedan
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
324 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
