Question about Toshiba 36HF72 36" TV
4 yr old Toshiba jumps when turned on
My tv jumps for about 15 minutes until it warms up and then it slowly stops and the picture is fine. It does this every time I turn on the tv.
    Problem Solver:
  • 8 Answers
See this link: http://www.fixya.com/support/t157556-picture_jumps_flashes_first_5_minutes seems to be a common problem among Toshibas that use a Hyper scan module.
Posted on Jul 25, 2007
    Genius:
  • 1,074 Answers
Take it to a tech if you have not done so. your problem is lose solder.your board needs to be rsoldered over to connect your component properly over the years heat from the operation of the tv cause the soldr to lose grip on the board.good luck
Posted on Mar 23, 2007
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
Have a 5 yr old 50 inch Toshiba projection TV. When turned on, the picture is "scrambled" for 30 minutes and then starts clearing up
Most common problem on Toshiba tv's is the so called nexthyper module thats were your problem is,normaly they have bad ground connections,a tv tech can fix it.
Mar 22, 2010 | Televison & Video
Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Mar 25, 2009 | Westinghouse SK-32H240S Television
Mitsubishi TV picture rolling
Look on the back and see if you have an adjuster.(It should say
H-HOLD) Just turn it very slowly until the picture stops rolling,You can do this by watching the tv screen in a mirror.
Please rate this solution.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Picture "jumps" at startup for about 20 minutes until warm.
You have some leaky filter caps. They are: C2C52 = 10 MFD 50 VOLT (off the base of Q2C51 on the signal board)Also check C2P05 = 100 MFD 16 VOLT (off pin #3 of IC2P01 on the signal board) and C2P03,C2P08 = 100 MFD 16 VOLT both on the signal board.
Sep 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 36HF72 36" TV Logo
167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
