Question about Samsung Cameras
Samsung vp d361i camcorder has error d problem intermittently and is also noisy when recording or reviewing the tape. am told the deck assembly needs to be replaced. is this correct?
  • Anonymous Mar 07, 2009
    My camcorder flashed D for eject, and wont play the taoe
5 Suggested Answers
poolseman
  • 206 Answers
SOURCE: recording
This sounds like the CCD sensor is faulty ( this is the device that generates picture in both v-cams and normal digital cameras and sits behind the lens ). Playback is fine but no image ( or very 'noisy' image ) in capture mode. Easy to repair but one has to put a new CCD block in.
Posted on Sep 04, 2007
  • 73 Answers
SOURCE: camcorder wont playback
SOUNDS LIKE YOUR CASSTEE COMPARTMENT IS BAD.. TRY CLEANER CASSTEE.. MAYBE THIS WILL PROLONG THE AFFECT. LET ME NO IF THIS HELPS
Posted on Mar 02, 2008
creeperz
  • 52 Answers
SOURCE: Samsung camcorder
Although my question might sound stupid, but did you charge the battery? The camera should be having a li-ion battery, which does not retain its charge for long(a week or so) which gives the battery a longer life.
If this is not the problem, could you explain the "ticks like a clock" in detail.
I could also be due to the tape getting jammed.
Posted on Mar 19, 2008
SOURCE: samsung VP - U10
the Capstan servo has corroded and needs to be replaced
Posted on Jun 02, 2008
SOURCE: I have a samsung digital
I don't know if idropped my camera or what should i go to the store to get it fixed or what should I do
Posted on Jul 01, 2008
Fast tape playback for samsung vp-l770 can't watch at normal speed on camcorder?
Tapes recorded on one camcorder very rarely play back satisfactorily on another machine - you will have to use your old camcorder to view them, or else get them transferred to DVD
Oct 07, 2016 | Samsung VP-L770 Hi-8 Analog Camcorder
Samsung VP-D361 Mini DV Digital Camcorder - have not used for a year and now it will not close the tape compartment. I have tried several tapes but when you push the tape in and push down the edge to close...
will it close with out a tape in. if its not doing it with the tape in there is a motor that pulls down something cannot remember its name. so when the deck goes in it can lock in place and hit the switch. if the switch has been damaged it will just eject the deck again. has one swith to say tape in and other switch is for table loaded. sounds like the loaded one is at fault. happens if you leave a tape in for a long time and not been used.
Sep 30, 2013 | Samsung VP-D361 Mini DV Digital Camcorder
My Camcorder Breaks the tapes
Your camcorder needs to be cleaned and or serviced ASAP. Please do not use any more tapes, as you may have a stuck roller head or sticky contact surfaces that can "catch" the tapes intermittently.
You should be able to have it serviced very cheaply at a camera store, but I would not use it any further for danger of potentially ruining the camera.
Mar 20, 2009 | Samsung Video Cameras
Samsung VP -D103i
If your camera uses video tapes, they have a little sliding piece on the back to stop you accidently recording on an important tape you want to keep. Slide it over for 'save' to 'rec' and you can record on it.
Aug 31, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Driver
DOESNT PANASONIC HAVE FREE DOWNLOADS?
Feb 23, 2008 | Video Cameras
Samsung VP 500 L Help !
BAD CCD. SAMSUNG IS KNOWN FOR THIS. YOUR OLD TAPES WITH GOOD RECORDINGS PLAYBACK GOOD? YOU CAN RECORD AUDIO BUT NO VIDEO ? IT IS A BAD CCD
Oct 17, 2007 | Samsung VP-W70U Camcorder
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Cameras Logo
27 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
