Question about Lexmark X4270 All-In-One InkJet Printer
Error 1203 how do i fix this?
  • 837 Answers
That error indicates is a cartridge is installed incorrectly, ie the cartridge is in a different cradle than the driver thinks it is.
OR you have a shorted cartridge, & need to replace it.
Try cleaning the cartridger connections, in the carriage & on the cartridge. Use some lint free cotton & isopropyl alcohol, wipe from the top of the foil strip down to the printhead.
DO this until the wipe comes away clean. The connections in the carriage can also be just as dirty.
Posted on Nov 26, 2008
  • 685 Answers
Please give me more info
  • Juanita Vega
    Juanita Vega Nov 26, 2008
    Check to see if any ink is smeared inside the holder where the contact panel is located. Normally gold contacts.
    Clean off the contacts with a paper towel or q-tip.
    Then try reprinting the alignment page. Then print the test page a few times.
  • Juanita Vega
    Step
    Action
    Power off the All-In-One (AIO) and remove the power supply from the
    back of the unit. Wait 30 seconds, then reinsert the power supply and
    power the AIO on.
    Did the error message return?
    Yes: Continue to step 2.
    No: Print a test page. If the test page prints, the error is resolved.
    Power off the AIO and remove the power supply from the back of the
    unit. Open the top cover of the AIO. Using the carrier belt, gently
    move the cartridge carrier to the middle of the unit.
    Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
    Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
    No: Continue to Step 4.
    5
    Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
    Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
    No: Continue to step 6.
    6
    7
    Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
    Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
How to fix error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Error 1203 I'm getting error 1203 on the printer. I have new cartridges in. Fresh paper. Still getting error 1203
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Nov 26, 2009 | Lexmark X7170 All-In-One InkJet Printer
I have error eading 1203 what is that and how can
I have an error reading 1203 that won't let me print. Message consult users guide.
Oct 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Seen this lots with dell printers.
or
Mar 24, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark 7170 error 1203 when it turns on
1203 Printhead
short-circuit in
printhead.
Replace print
cartridge(s).
Dec 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Error
error # 1203 how do fix it
Oct 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1203 What do I do?
Cartridge Error: 1203 Your print cartridge has a short.
Aug 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell Printer 924
I kept pressing menu, since it would not bring it up turned it off and on, it fixed itself, now it is printing.
Jul 14, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
