Question about Nokia N73 Cellular Phone
Powerpoint (quickpoint) not working
I tried eevry possible way, but my n73 is not able to load ppt and pptx files
althouh, word ie doc is working fine in my system
please assist
  • vivek_sha272 Nov 27, 2008
    okie, let me try and get back to u later :)
    Thanks for the help although
  • 136 Answers
Reinstall QuickPoint from your Phone driver CD and also install the Flash Player. Then try.
Posted on Nov 27, 2008
How do I recover a corrupt PowerPoint file?
If there was such problem, the simplest decision is described here:
Method 1:
Move the PowerPoint to different location : this is first and very useful troubleshooting method to repair PPT problems . Copy presentation and paste it on other computer hard.
Method 2: Open presentation in MS word document:
If you have tried above method, but still facing same problem then try to open corrupt PowerPoint in MS Word. Follow this below steps:
•Open MS Word.
•Click on Open button of File menu.
•Select Files of type box and navigate to your corrupt file, Open it.
Method 3: Use Safe Mode
To see your presentation in safe mode, first of all you will have to run PowerPoint in safe mode. Follow these steps to do it...
•Click on Start button.
•Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
•Now press OK button.
•Restart your system, during restart press & hold F8 button to start window in safe mode.
•Open & see your presentation.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise, for example as it is described here:
https://social.technet.microsoft.com/Forums/en-US/50c99db5-9167-44fe-b625-e2682fa682ca/corrupt-powerpoint-file?forum=officeitprolegacy
And also there is a universal decision and "an edition choice" it watch it here:
Online PPT repair tool
Sep 10, 2015 | Microsoft PowerPoint for PC
Fix corrupt powerpoint file
Use PowerPoint Repair Toolbox is efficient PPTX corrupted repair solution for damaged presentations in corresponding format so you may open these documents anytime and regardless the reason of file damage.
For more: https://www.pptxrepairtoolbox.com/
Sep 06, 2015 | Microsoft PowerPoint for PC
Powerpoint 2003 corrupt problem
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
Jul 27, 2015 | Microsoft PowerPoint 2003 for PC
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
Feb 06, 2015 | Microsoft PowerPoint 2007 for PC
I want to open powerpoint presentation.
then, go to format -> slide design, choose to show all documents, and choose the corrupt powerpoint file. now, go to insert -> slides from file, and select the corrupt powerpoint file. make sure you are set to insert all slides, and then import. if that works, great! i suspect, however, that you might crash at that point. if so, try repeating the process, inserting specific slides one by one until you find the problem one. after that, save the file, making sure that fast saves are off (in preferences / save).
if you are unable to open your powerpoint files then try pptx viewer tool. this utility recovers your corrupt and damaged powerpoint presentations (.ppt, .pot, .pps, pptx and ppsx formats) from ms powerpoint files. http://www.pptx.viewertool.com/
visit:- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
http://www.pptx.viewertool.com/ http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/1128-how-do-i-recover-a-corrupt-p-point
Jan 19, 2015 | Microsoft PowerPoint Computers & Internet
My ppt file got damaged i cant open it.while i try to open tat its asking for repair option.after selecting repair option it not opening,anybody tell me the ways to open tat file
When do you start MS PowerPoint then office check for problems such as add-ins or file extension that would not start powerpoint. If you find such problem then try to start your MS PowerPoint in safe mode.
If you will be able to start in safe mode then there is a problem with add-ins. So disabling the add-ins can fix the problem.
You can disable the add-ins by following steps:
  1. Click the File tab.
  2. Click Options.
  3. Click Add-Ins.
  4. On the Manage menu, click Disabled Items, and then click Go.
Dec 23, 2010 | Microsoft Office Professional 2007 Full...
Ppt is not open and ppt convert pptx that ppt file not opan
In case the PPT file is corrupted, you could not open it until you repair it using some software. Previously when I too faced the similar situation, I was able to repair corrupted PPT file using Repair PPT software. For more details you can visit the below mentioned website.
http://www.repairppt.net/2010.html
Oct 02, 2010 | Microsoft Office Professional 2007 Full...
How can i convert my pptx file to word cause it can't be opeened
PPTX is Powerpoint 2007 format. Microsoft has a free viewer for that version if you dont have Office at all, available at http://www.microsoft.com/downloads/details.aspx?familyid=048DC840-14E1-467D-8DCA-19D2A8FD7485&displaylang=en You will only be able to view, not edit the document using this viewer.
As an alternative, if you have the 2003 Office suite, you can download the compatibility pack which will allow you to open .pptx files in Powerpoint 2003, .docx in Word 2003, etc. That download is located at http://www.microsoft.com/downloads/details.aspx?FamilyID=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
Feb 20, 2010 | Microsoft Computers & Internet
Pptx file converter for office 2007 to office 2003
I am looking for office 2003 2007 converter for using with a word doc
Jul 25, 2008 | Microsoft Office Professional 2007 Full...
Nokia N73 Cellular Phone Logo
136 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
