Question about Dell Computers & Internet
Dell d610 latitude wont charge new battery
I bought a used dell d610 latitude laptop and couldn't charge the old barrery so bought a new battery and it wont charge that either! ??
  • 1 more comment
  • rorycl1 Nov 29, 2008
    thanks guys i think the problem is likely to be in the ac dc transformer lead. there is supposed to be a pin down inside the jack pin to laptop lead i think and it's not there. I'll look into that.Thanks Rory
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Are you sure the charger works? Does the laptop run without a battery?
  • Anonymous Mar 30, 2014
    sound card dell latitude d610
    Scholar:
  • 181 Answers
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Posted on Nov 27, 2008
Dell lattitude d610 notebook wont power up. Got new battery yesterday, worked fine. Shut it down & now it wont power back up & yes the battery is fully charged.
Take the battery out (1 screw in the bottom of the case, then it pops out with the tab) and attach the power adapter, and see if it boots up now. If it does, you have a problem with your battery.
Did you have this problem before the new battery?
Aug 11, 2010 | Dell Latitude D610 Notebook
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
Dell latitude d610 not charging battery, I bought a new replacement battery thinking the old battery was the problem.
See the Adoptor status in the bios, if it is not detecting it the adoptor fault otherwise you have mentioned above you have already replaced the battery then it is m/b issue
Dec 28, 2009 | Dell Latitude C640 Notebook
Dell Latitude D610 wont charge
the charging system on your motherboard has blown a capacitor, if it is still under warenty you should call 1-800-456-3355. to get it repaired.
if it's out of warenty, they can help you buy the right part
Aug 14, 2009 | Dell Latitude D600 Notebook
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Battery charging
if it is the original battery, then the answer is buy a new battery. The average life of a portable battery is 300 to 500 discharge/recharge cycles. (1 to 2 years normally) If it is the original battery, then it is going on 5 years old and due for replacement
Mar 25, 2009 | Dell Latitude D610 Laptop Computer -...
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Power for battery on DELL laptop Latitude D610 as posted FixYa
In the BIOS, does it show the battery and it's current state? As weird as it sounds, I've fixed an issue like this on a D600 by updating the BIOS to the most current level. Weird, but true.
Dec 22, 2008 | Dell Latitude D610 Laptop Computer -...
Computers & Internet Logo
389 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
