although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
You likely have a bad ignitor. It's like a mini element that heats up and then ignites the gas once the valve releases it. When the ignitor gets old it doesn't glow bight enough or draw enough amperage so the gas valve won't open. If you set bake and see a glow coming from under the plate in the oven but the burner never lights that's your culprit. They probably cost about $50-$80. Good luck!
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
the problem is the ignitor or both of the ignitors are not working properly remember just because they glow doesn't mean they are good they have to draw at least 3 amps to open the gas valve if not they will glow all day let me know how you make out
This could be a defective ignitor (glow bar) or gas valve (safety valve). If you gently tap the safety valve and it lights up very likely ingnitor problem
ignitor lights up , so im assuming its a glow bar style ignitor. replace it, although its glowing its not glowing strong enough to release gas from the valve, the fact that it lights at all is a sign that the vavle isgood and control to turn it on as well!Common,Common problem
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
