Question about MSI Computers & Internet
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
    Sergeant:
  • 177 Answers
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Posted on Nov 26, 2008
I have a MSI P4 M900M3 so can u help me that which procesor i can use here. Intel celeron dual core & intel pentium dual core.pls inform with procesor no.
Posted on Nov 12, 2010
  • 1,031 Answers
Yes it can support it ,this Supports Socket 775 for Intel P4 3xx/ 5xx/ 6xx/ Pentium D, Celeron D, Conroe, Core 2 Duo processors .below are some of the features and specification of the main board
Features/Specifications: Main Specifications Product Description MSI P4M900M3-L - motherboard - micro ATX - P4M900 Product Type Motherboard Form Factor Micro ATX Dimensions (WxDxH) 7.9 in x 9.6 in Chipset Type VIA P4M900 / VIA VT8237S Multi-Core Support Dual-Core Max Bus Speed 1066 MHz Processor 0 ( 1 ) - LGA775 Socket Compatible Processors Pentium 4, Pentium 4 Extreme Edition, Celeron D, Pentium D, Core 2 Duo 64-bit Processors Compatibility Yes RAM 0 MB (installed) / 2 GB (max) Supported RAM Technology DDR II SDRAM Storage Controller ATA-133, Serial ATA-300 (RAID) USB Ports Configuration 8 x USB Storage Ports Configuration 2 x ATA, 2 x SATA Graphics Controller VIA Chrome9 HC Audio Output Sound card - 7.1 channel surround Networking Network adapter - Realtek RTL8201CL - Ethernet, Fast Ethernet
hope this solves your problem.pls appreciate by rating as fixyaa thanks and Godbless
Which fan/heatsinks can be used on an MS-7174 Ver 1 motherboard? It seems there needs to be clearance for some capacitors to fit beneath it.
Heatsinks are dependent on the type of processor that you have, I recommend that you call Microcenter or fry electronic
Apr 22, 2015 | MSI Computers & Internet
Is it possible to use intel duel core E5400 processor with MSI B75MA-P45 Motherboard? or any other motherboard support DDR3?
Hello here is the cpu list, for the asus board:
http://www.asus.com/Motherboard/P5QLCM/#support_CPU
Here is the msi site:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=Basic
Your current cpu will not fit on the msi board, because it is a different socket.
The asus board has socket LGA 775, and the msi board has socket 1155.
You have to buy a new cpu for the msi board, to make it work.
Here is the cpu list:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=CPUSupport
If you want to keep the socket 775, you probably have to find a used mainboard, because this socket type is phased out.
Some online stores still have this mainboard type available, but a new mainboard will have the DDR3 ram socket.
Good luck
Feb 13, 2013 | EliteGroup 945GZT-M (V1.0) Motherboard
Ms 7529
Hello here are the supported cpu list for your mainboard:
http://www.msi.com/product/mb/G31M3-F-V2--3-Audio-Ports-.html#/?div=CPUSupport
You maybe have to upgrade the bios to support the new cpu.
May 25, 2012 | Intel Motherboard
What is a version of Biostar G31d-M7
Socket LGA 775
Supports Intel Core 2 Duo/Pentium Dual-Core/Celeron Dual-Core/Celeron 400 Series Processor
Supports FSB 800/1066/1333MHz
Support Intel Hyper-Threading Technology
FSB 533MHz is not supported by this motherboard. CPU TDP over 65W is not available. Please refer to CPU support for further information.
hope this helps
Mar 02, 2011 | Biostar G31D-M7 Motherboard
CPU died
Socket : Socket 775
Type : Support Intel LGA775 CPU
FSB 800MHz
As long as it is socket 775 you can go up to 3.4GHz
Jul 24, 2010 | AOpen s661FXm-7S Motherboard
Intel Celeron 430 Conroe-L 1.8GHz will it work with this board
945pl is a cipset and not the full model number for the board.
When you have the proper board model you should go to
http://processormatch.intel.com/COMPDB/default.aspx
That will tell you for sure
Aug 11, 2009 | Intel 945PL Socket 775 uATX Audio DDR2...
Upgrade intel celeron processor 798 MHz
it is better to use intel core2 dueo or intel quad core processor
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Uppgrade of processor!
looks like that mobo can only suppoport up to 53 mhz front side bus for a celeron d processor
wht tht means is tht u can get any cpu tht has the front side bus up to 533mhz with the 775 socket forur motherboard
and forpentium 4 its 800mhz and agian any cpu with up to 800 mhz front side bus and 775
so ur best cpu for tht mobo would be the SL7RR it supports hyperthreading
here a direct link to intel'ssite
http://processorfinder.intel.com/details.aspx?sSpec=SL7RR
SL7RR
3.40 GHz
800 MHz
109.6 W
66
512 KB
2 MB
775
0.13 µm
yes
pls rate my answer if i helped u
Sep 22, 2008 | Computers & Internet
Cpu compatibility
Hi Buddy,
Thanks For The request.
Heres Your Information:-
http://safemanuals.com/user-guide-instructions-owner-manual/ASUS/P5RD1-VM-_E#
This Is English Version Of your Motherboard. Just Click The pdf file and download. Open with adobe acrobat Reader.
Compatable With Socket 775 CPU. Pentium D. Pentium 4.Or Intel Celeron Processors. Your CPU should be fine on this Motherboard, Providing It has the correct Pins. ( Socket 775 )
Hope this Answers your Question.
Mike @ compurepair.
Mar 15, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
843 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
