Question about Epson Stylus C60 InkJet Printer
I cannot print through a shared printer on my computer network. The host computer itself can print but the clients that prints through the shared printer cannot print.I want you to help out on this issue
  • 2 more comments
  • geconak Mar 13, 2009
    C60 printer with loaded drivers on my windows XP sp3 PC. wireless network with ATT U-Verse. Cannot access printer through network from my Windows Vista laptop. I find the printer on the network clicking my PC icon but when I select the printer I get the message:"Windows cannot connect to the printer.The local print spooler service is not running.Please restart the spooler or restart the machine" I did the restart but it did not help.Do I need to install drivers for Vista on my laptop. I was told that I should not have to. Thanks for your help!
  • Gerry Millward
    Gerry Millward May 11, 2010
    engrt009
    If you don't respond to valid queries such as these, it is very difficult for us to help. Respond please!!!
  • Maurice Holliday May 11, 2010
    What, if any error do you receive when printing from the other computer?
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Peer-to-peer?
    Is the host a true server (i.e. Server2003 SBS, etc)?
    What is the OS of the host, clients?
    Do you have static IP's or DHCP?
  • 353 Answers
Since engrt009 no longer seems interested in solving his problem, I think we can say this is "Solved by Poster".
geconak - this is clearly a network problem - nothing to do with the printer. I suggest you repost this problem in a Windows Vista forum.
Posted on Mar 19, 2009
Tip
How to connect a wireless printer.
First things first. Make sure that you have the same username and password set up on the machines you want to use as your print server and the machine(s) you are going to print from, the or the "Client".. This is required so that you can communicate with the other machine(s), "Clients".. Once you have the machines’ usernames and passwords set, you can turn to the machine with the printer attached to it. (which we will call the print server). From this machine (The one we have called the print server), we will need to set up the default printer on it. So install the software & drivers for the printer. Test that you can do a "Test Print" . Then we will need to go to Printers and Faxes in the control panel. You need to right click on the printer that you want to share, and choose properties. When you get to the properties page for the printer, click on the tab that says "Sharing". That will enable the client PC to "See" & be able type in the printer’s name. Usually the software will put the "Printers" name in. It will be grayed out until you click the radio button to share it.
Now, when you are ready, go to the "Client" computer you want to print from, wirelessly. When you set up your printer, go to install the printer, and you install a "Networked Printer" you then you "Tell" the installer where the "Printer" "is on the network". So when asked for location you then you can "Browse" for the printer, or type and your IP address OR host name,and Printer name too.. Mine is 192.168.1.64 OR heaven, so I typed 92.168.1.64, OR the Name of the machine. So say: As in my case, 92.168.1.64BrotherD or heavenBrotherD. Anyway, this will then go away, and connect to the "Printer" and do some houskeeping & finish, from then on, you will be able to print. try a test print the same as you did on the "Print Server". If you wish to print from say, Word, do it, by simply choosing the correct printer from the print menu that comes up whaen you try to print. Ensure you right click on the Printer Icon on Client and choose "Default Printer" too. You can also right click on documents and images files, and select "Print".
Also ensure that the print server is set to on, in Services too, on BOTH machines.
on Feb 06, 2010 | Office Equipment & Supplies
Our HP desktop and Dell laptop are both connected to a AT&T 2 wire router/modem. The desktop is connected to an Epson non-wireless printer. How can we print wireless from the laptop? The laptop is...
You have to install the relevant drivers FIRST (Just install without printer thats fine) on the host & clients and then make sure you "Share" the printer on the Host setup. (The one where the printer is attached). Then on the clients you install a "Networked" printer and "Find" it on the network. Now ALL the PC's need to be in same"Workgroup" and have "Sharing" enabled on each machine, they all must have a name & password too..
Jan 30, 2010 | Epson Stylus CX9400Fax InkJet Photo...
Hp laserjer p1008 printer wants to share with 10 hosts but printing not done properly by shared users so pls assist me for proper printing through network (Domain) host?
Please check your LAN settings and cross check your printer is on shared mode and check all the computers that all are having install that printer whatever the want to shared by them.
Sep 29, 2009 | HP xw4600 Workstation Linux Installer...
Toshiba e studio166 shared printing problem
try adding printer and browsing network for printer, it should see the host and printer and add using correct network path, if you don't see host computer "print server" then you aren't on correct network path
Jun 24, 2009 | Toshiba e-STUDIO166 Printer
Can't print from shared printer
Did you connect the printer directly to the laptop to install the drivers? If so, you need to change the port to the network location to //hostcomputer/printer. You should also have the same user name and password set on both machines and have the user rights assigned to the printer sharing.
Jan 24, 2009 | Epson Stylus RX500 All-In-One InkJet...
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Client Printing + Word/Excel access times
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
369
Aug 06, 2008 | Microsoft Small Business Server 2003...
Wireless printing
If the printer is set up as shared and is attached to a host computer on the network (like mine).
  1. start
  2. network
  3. click on the computer that has the printer that is shared
  4. click on the printer and select connect.
  5. the printer will be displayed on the bottom of the page when it is connected.
Apr 18, 2008 | Computers & Internet
Epson Stylus C60 InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
