Question about Nikon Coolpix L11 Digital Camera
Len's error How do I repair the lens error I changed the batteries and it still doesn't work it only says lens error. How do I fix it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Posted on Dec 30, 2009
The camera was dropped while it was on. The lens is stuck in the open position. When the camera is first started it sounds like tiny gears spinning but not catching. It doesn't really grind or...
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon SD cameras:http://www../Device/Canon_Powershot_SD880 or
http://www..Guide/Disassembling-Canon-PowerShot-SD800-IS-Lens-Assembly/4093/1
Also you may try this Canon "Lens Error" troubleshooting guide >>http://camerarepair.../fixing-lens-error-on-digital-camera
6.To download the complete service manual for a similar camera model can be downloaded at the link below:
http://www../canon_powershot_digital_elph_digital_ixus.pdf/download.html
Wait 10 sec and click Get Manual .At the bottom of the page.
10_8_2011_7_21_11_pm.jpgCanon SD990 IS digital camera lens with ccd parts can be purchased from eBay >>PARTS-REPAIR-/140607486728#ht_483wt_1642
Oct 08, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
When i turn on my canon ixus 850 IS the lens doesn't extend and the display says 'lens error restart camera'. What can I do to resolve this? James
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Aug 24, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens error. Please restart camera. The lens doesn't zoom in and out.
Aug 06, 2011 | Canon PowerShot SD1000 Digital Camera
When I turn my DMC-TZ3 on, the lens open's up then shut'soff then open's again then shut's off again and a message appears saying shut camera off and try again, will not stay open why is...
A recycling lens is usually caused by either a low or worn out battery (how old is your battery? If more than a couple years, it would be definitely time for a new one. Here's a selection.). If a new battery doesn't help (but it really does sound like you need a new battery), the next problem that could cause this is a lens error. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My lens doesn't open. It prompted lens error
Jun 11, 2011 | Nikon COOLPIX S230 Digital Camera
When i turn on my camera it says lens error and the lenso stays half way out
Hi.
If the lens do not extend completely, then problem is lens itself.. When this happens the motor is unable to retract or to extend the lens either because one of the lens rings is damaged, or because of dust inside lens rings.
Sometimes lens error occurs because batteries are nearly drained and insufficient power to lens motor. This will cause the lens rings getting out of alignment and you get jammed lens. In other cases the lens gets jammed either because of dust or dirt or because of a mechanical problem.As a result the camera freezes with lens half of the way out.
In some case the len
s can be unjammed manually (see the tips below), more commonly the lens and the camera must be disassembled and there is no other way to fix the problem.
Try the tricks below. They rarely work, but you never know:
Test always with fully charged batteries you need as much power as you can get to unlock the lens. Ensure that batteries are Alkaline or good working rechargeable.
If there is dust or sand in lens blow air with a compressor on top the lens..
Sometimes methods like helping the lens movement while turning camera on and off works, but this methods can do more damage to the camera. Help out the lens while turning the camera on.
Remove the battery, point camera to the floor and put back the battery while holding on button and still pointing to the floor. Turn on this way and see if it works.
Connect camera to USB (that gives extra +5V power) and turn on still pointing to the floor.
You find some more detailed hint using the links below. The links refer to digital cameras (no film). In your case disregard all the parts that do not apply( e.g some hint is for lens not retracting - the cause of the problem is the same and I reported the link).
Lens not retracting on digital camera.
Fixing Lens Error.
Lens Error.
Most of the time the lens error must be repaired disassembling the camera. Sometimes lens rings must be replaced. If you need a quote on repair see:
Repair.
Regards.
Ginko.
May 31, 2011 | Nikon COOLPIX L18 Digital Camera
Powershot A570 IS-lens error, restart message-lens partially out worth repairing? cost of fix approx $150-anything we could try ourselves?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 01, 2009 | Canon Cameras
Lens error in a Canon G10
Try restarting it a couple of times. If that doesn't make the error go away, the camera needs to be serviced. There is a really good site and all they service are Powershots. They are wonderful if you need to get service for one of these Canon Powershot cameras and they are really reasonable for the cost. Your problem is on their site. Try going to: www.camerasandparts.com Look at their service and repair and you should see it there. They are amazing for service on these models. I wish you a lot of luck with it, that's a really great camera.
May 09, 2009 | Canon PowerShot G10 Digital Camera
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
Dec 23, 2007 | Fuji FinePix A205 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
53 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
