Question about Kenmore 63942 Dryer
Loud thumping sound
The dryer works fine but it makes a loud thumping sound similar to the sound made if you had a tennis shoe in the dryer.
  • Anonymous Dec 05, 2008
    how to install dryer rollers
    President:
  • 2,992 Answers
It's probably time for new drum support rollers. There are two rollers the drum rides on and their bearings can fail, which makes them noisy and also makes the drum wobbly while it turns. Replacing the rollers isn't difficult, and you can do it yourself if you feel comfortable working with hand tools and are patient.
Here's a good site with information on belt replacement and other repair tips, and a source for parts:
http://repair2000.com/wpoolbelt.htm
Posted on Nov 26, 2008
LG DLE5977W THUMP DRUM WAS CRACKED-REPLACED FROM APP.PARTS.COM NEW DRUM OUT OF ROUND.SENT NEW DRUM SAME THUMP.REPLACED ONE ROLLER I SAW WAS BAD-SAME THUMP.REPLACED OTHER THREE ROLLERS-SAME THUMP.HELP
Anything is possible but I doubt 2 drums are bad. Since you replaced all the rollers and I assume you installed the drum on the rollers properly, i would look at the other drive parts. It might be a bad idler pulley and bearing. That is the small pulley that is spring loaded and puts tension on the belt. Check the complete assembly for any unusual free play that might cause a thump. Also look at the belt itself for any cracks or bumps.
Mar 02, 2015 | LG Dryers
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
This started recently, my dryer makes a loud noise while it's drying. It sounds like tennis shoes are in there drying.
There are usually 3 rollers that the drum rides on as it spins. Sounds like one or more of the rollers has worn out
Apr 03, 2010 | Dryers
Thumping noise (similar to shoes drying) and burnt smell
that one needs a serviceman to look at it too many variables as to cause
Jan 23, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
LG DLE3777W dryer thumps when running . It sounds like there are tennis shoes in the drum.
Probable cause is the bearing on the wheel that turns the drum is worn out. They are easy to replace and should cost less than $25. for the part.
Remove the front of the dryer and turn the drum by hand, you should be able to tell which side is worn.
Be sure and unplug first.
Mar 16, 2009 | LG DLE3777 Electric Dryer
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Kenmore 63942 Dryer Logo
435 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
