Question about Toshiba Satellite Pro 490CDT Notebook
Can't get power
I havae checked the power supply. It is fine but there is no power getting through to the laptop.
  • Dorrie Sinclair Jan 08, 2007
    The green light is showing on the adaptor but the LED's are not doing anything. It is a brand new Toshiba adapator. I am wonering if there could be anything wrong with the laptop on/off switch but don't know how to check it. There is no power in the battery.
  • 624 Answers
Hi Doc, How have you determined that the A/C adaptor is working correctly? When you plug the adaptor into the laptop do any of the LEDs do anything? What about the battery, can you run off it?
Posted on Jan 08, 2007
Asus monitor was working fine switched it self off then will not switch back on ve278 model
Check it is proerly plugged in and there is power getting to it. Then check the fuses at the pug and then the internal if you get no joy with the plug fuse.
If it has a power supply check the power supply
Feb 18, 2015 | ASUS "Us Ve278 Q 27""Led Lcd Monitor"
Out of range 90.0khz/60hz
does the dock havae a power button? if so, place laptop on dock while cosed and turn on through the dock.
Feb 06, 2013 | LG W1943SS 19" Monitor
When you plug the power cord in the lap top does not even power up there is nothing
Your power supply is either faulty or your computers power supply area is faulty, if you have a light on the power supply usually green, you can tell that way if your power supply is working, the other way to tell would be a multi meter checking dc voltage from the power supply's end, if you get around 13-14.5 volts somewhere in that area, then it is supplying voltage and is okay, which would mean it would be your power supply in the computer on the motherboard is faulty, which needs serviced by the company if under warranty or computer tech, if your power supply is all the way in and plugged in the laptop, it's usually one of those two issues, it can still work on battery and sometimes it wont if it is the computer, i would first suspect the power supply itself first, and check it while plugged in , even plug it into another outlet just to rule that out. if the power supply is bad and you replace it, the computer should work fine, unless there is internal damage in the computer. Hope this helps.
Dec 01, 2010 | Computers & Internet
My laptop acer extensa 4420 5239 will not power on.The battery light goes green if i charged it fine. It seems that the switch is having a problem or might be the power supply. how would i know?. please...
Probably there is a problem with your battery charger or power supply. It might not charging your battery. The only reason why the laptop would not power on if there is no power supply coming in, either from a battery or a direct connection from the power supply. You can check your battery charger or power supply using a multimeter. Check if there is a voltage reading coming from your charger.
Oct 30, 2010 | Computers & Internet
Hello sir in my laptop not showing icons,start bar with refresh point
msut be problem with the explorer
press ctrl+alt+del and then a box opens
in the box open file on top left and choose new task and type explorer.exe and check it
you hava to get everything back
Jul 22, 2010 | Dell Inspiron 1464 Notebook
We hava a viewsonic 1912w-4, model VSS10866 and
I'm assuming the computer is coming on alright. Double check this by putting another monitor in place of the Viewsonic. If the old monitor displays everything like normal then something has failed in the internal power supply. Take the Viewsonic to a reputable repair person or check my website www.micromendllc.com.
Mar 02, 2010 | Computers & Internet
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Toshiba Satellite Pro 490CDT Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
