Question about Garmin (010-00583-00) for nuvi 750/760/770
Our car charger did not work.
We have a 4WD car with a charger with a cigarette on it. I have an airplane that is charged by this and only this. Everything is plugged in but the sensor light was not turned on. The car was off and I have now idea why it is not working. I want to know soon.
  • jcarroll81 Feb 28, 2009
    The charger point in my car no longer works. I plugged my GPS charger in and the power light no longer comes on.
The car had to be on.
Posted on Nov 30, 2008
I have a garman Nubia 1490. Works OK but will not charge battery when plug into car charger. Have used charger from unit supplied.
Do other devices work from your cigarette lighter? If so, check to see if the red light is illuminated on the charger. If the light is not on, the fuse in it is either bad or the charger is defective. It is not economically worth while to have the charger fixed if it is bad. If your GPS does not use a traffic receiver that is embedded in the charging cable, then any cigarette lighter charger with the right plug for your GPS will work. Otherwise, buy either an OEM or after market replacement.
Mar 22, 2017 | Garmin Nuvi 1490LMT GPS Receiver
The battery on my 1194 S420 needs to be charged. I can't open the truck to get to the battery. What do I do? HELP!
You can buy a trickle charger that will charge the battery through the cigarette lighter socket, but it won't charge the battery quickly. I'm guessing that the "1194" should read 1994. Some newer cars won't work with a cigarette lighter charger.
If you have a manual transmission you can actually push start the car by getting it rolling, putting the ignition in "run", and then popping the clutch. Not something that you can do if you haven't seen it done before, though.
Best wishes and I'll keep my fingers crossed that it works out.
Jan 31, 2011 | Mercedes-Benz S-Class Cars & Trucks
My nuvi 760 has never charged from the car. Is there another way to charge it?
It can be charged from a computer. Connect it to your computer with the mini USB lead and it will charge. It takes about 8 hours compared to 4 hours with the car charger or with a mains charger.
If your car charger isn't working it's likely that the fuse is blown. I presume you checked the cigarette lighter socket first and that it's working. If not try something else in the socket and make sure that's not the problem.
At the end of the charger lead plug, that goes in the cigarette lighter socket, there's a ring. Unscrew the ring and the plug comes apart. Be careful not to lose the silver tip. When the plug comes apart you'll see the fuse. You'll get a replacement in any car electrics shop or anywhere that supplies satnavs. I hope this solves your problem.
Jan 08, 2011 | Garmin GPS
My nuvi 760 doesn't charge in the car. is there another way to charge it?
Jan 08, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
Battery, 8.4V 900mAh NiMH 7-Cell. Works with RC Airplane Models: Commander: how long does it take to charge?...
Hi
From the picture this looks like a Firebird product? If you're using the AC charger that came with the product, charging is usually overnight. If you're using a generic NIMH charger then 15 - 20 minutes is normal but its all based on your charger.
May 11, 2010 | Challenger Battery, 8.4V 900mAh NiMH...
Nokia 3310 charger.. won't charge help me..
if its the car charger check the cigarette lighter fuse and also the charger fuse
Sep 25, 2009 | Nokia Car Charger: 3310 3360 3390 3395...
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin (010-00583-00) for nuvi 750/760/770 Logo
507 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
