Can I mess something up?
If I take the casings off to get to hinges is there any way I could mess anything up so horribly that it would have to be replaced? I spend most of my money on this laptop from my girlfriend's sister and need it for online classes so I have to make sure.
  • May 11, 2010
    Why do you want to get to the hinges? What is going on and what are you trying to do?
    Problem Solver:
  • 7 Answers
You can take the casing off as long as you try not to touch the circuit boards of the laptop, if the case doesn't want to come off don't try yank it off look to see if you've missed any screws or anything
also make sure if you unscrew things that you remember where they go and that you put the screws in a SAFE place and do not lose them
otherwise it should be fine as long as you are patient and careful
Posted on Dec 04, 2008
E6 error code on cs6000i
it's possible that it's a mechanical or electronic problem or something has worn or is loose, it needs to be serviced
Feb 06, 2012 | Brother CS6000i Computerized Sewing...
I have an Epson 6000 cX. I had a few jams (with some really thick paper) which I cleared, At the same time I replaced a cartridge. Now it makes a horrible clicking sound like something is not aligned or...
you've propably messed up the alignment of the paper feed gears, maybe a little careful (!) tweakingwith a flatheaded screwdriver can help it, if not, then yes, you broke it.
Sep 26, 2010 | Epson Stylus CX6000 All-In-One InkJet...
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Dryer door/casing is loose on hinge side of door
you can go to repairclinic.com and enter your model number. It will list all the parts. Find your hing and screws and your set.
Apr 13, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Blower motor makes loud noise when on high
I have a 2004 dodge ram 1500 with the same problem, vibrating blow fan when on high, pulled the blower fan out and found a piece of the hinge from the recirculation door and felt the recirculation door sitting up on the vent of its hinge. Crappy engineering once again.
Feb 14, 2009 | 2004 Dodge Ram 2500
I have a Toshiba Satellite series laptop that was dropped and the screen was damaged. I've gotten a replacement but I don't want to mess anything up by changing it myself. Anyone have suggestions? I've...
you'll need to pry the screen gently forward(away from the plastic casing)...along the side s of the screen will be the hinge brackets.....4 screws (2 either side) hold the screen in place...undo these screws and the screen will be free....the only thing connecting screen to computer will be the video ribbon cable which connects to the back of the screen via a plastic pressure clip...release the clip and your done.....remember to be very careful when installing the new screen as its easy to overtighten the screws and damage the screen
Jan 07, 2009 | Toshiba (225EXTR5)
Laptop screen suddenly turns white display
Toshibas have a HORRIBLE HORRIBLE HORRIBLE overheating problem. In your case, it sounds like the video card is overheating. Use compressed air in a can to blow dust out from inside your laptop. Then lift it up off your desk by propping it with something small, or buy a notebook cooler base. the problem should go away. I'm surprised you haven't experienced auto-shut-off yet.
Dec 10, 2008 | Toshiba Computers & Internet
Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
Jun 01, 2008 | Frigidaire PLMV168 Microwave Oven
Computers & Internet Logo
David Payne
David Payne
