Question about Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability
From left hand side 10 keys not working
Hi I am new to keyboards. I think about 10 keys from left hand side not working. I am not sure it is a fault or mis setting.
regards
    President:
  • 2,992 Answers
You might check settings first. The keyboard might be set to a mode where those keys have some function besides notes. Try a master reset and see if hings start working.
If it was working and now those keys don't, a fault has probably developed. There may be problems with connections to the keyboard, or there's been a component failure.
Sometimes getting into these things and accessing the keyboard is a challenge, and it's possible to do more harm than good. If it needs repair, you're probably better off taking the keyboard to a musician's store in your area and asking them to give you an estimate for the work (or to recommend a servicer if they don't do the work themselves).
Posted on Nov 26, 2008
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
I have three keys getting malfunctioned /cords not changing in left side, on split board.can this be fixed?
If those keys work normally, it's hard to see how the key switches themselves can be bad.
Is your keyboard MIDI capable? If you play the same chords, does the MIDI output look OK?
Could it be that your keyboard simply can't play all of the different sounds at the same time? I know some are limited in how many simultaneous tones can be played.
Jun 09, 2015 | Music
No sound from first 10 keys on left side of keyboard
Most likely a ribbon connector has come loose between the keyboard and main board. If you're uncomfortable dis assembling your instrument, I'd take it to a repair shop.
Mar 02, 2015 | FIRST Music
Can I hit one key to play a chord and how do I do it
It depends exactly on the model of keyboard you have but in short look for the accompaniment button normally on the left hand side. With this pressed you can then get 1 finger chords in the left hand ( 2 fingers will give minor or 7th options ) check your handbook
Jul 12, 2014 | Yamaha Full-Size Keyboard
How to replace a defective speaker on the Casio CT-638 tone bank keyboard
Hi, Yes it can be fixed.
It may not need fixing, It may have just worked loose. If it is faulty then any general purpose speaker that will fit will be OK. Consider replacing both if the replacement is radically different.
Speakers can be as cheap as a few pounds.
Paying someone to do the repair is something else. It will take longer to take the keyboard apart than affect the repair.
Consider buying a replacement from eBay, second hand, and get a competent amateur to repair yours!!
Failing that, use the headphone out (which cuts the internal speakers) into a hi fi or external instrument amp.
Good luck, Chris the Fader.
May 21, 2014 | Casio Ctk-5000 Electronic Keyboard Piano...
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Jul 31, 2013 | Korg Pa50 Professional Arranger Keyboard...
Hi The first 11 keys of our keyboard have not woked since new. If my girls press the play/pause button then it works. Is this a fault of the keyboard or are we doing something wrong? Thanku
Check the switch to be sure the keyboard is in normal mode and not chord mode. This will cause there to be no sound unless you play a chord on those first 11 keys. Pressing play activates whatever song is loaded at the time, allowing full keyboard use.
I have an older Casio, and the same thing happens all the time, especially when I'm in a hurry and don't check where I put the switch.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 05, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
FIVE KEYS NOT OPERATING ON THE LEFT HAND END OF KEYBOARD. HAVE TAKEN BACK TO FACTORY SETTINGS BUT PROBLEM REMAINS
It's a hardware problem. You won't be able to fix the problem yourself. It has to be serviced by Yamaha. For that price it's probably just better to purchase a new model.
Nov 23, 2009 | Yamaha Full-Size Keyboard
Auto accompament failure Yamaha DGX220
I had similar problem out of the box; fixed by setting Function to Style Volume and adjusting upward.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability Logo
310 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
