Question about Fuji FinePix A205 Digital Camera
Card error I borrowed my sistter fujifilm camera and I put the memory card into my computer and the green light stayed on did not blink(also this my fisrt time using this camera) I looked in all my removeable disk on "my computer" and it would not read it and then I pulled out the memory card and put it back into the camera and now "card error" comes up all her 172 frames are lost, I want to know if there is anyway to recover the pictures? And if I format in the camera will that erase the pictures on the memory card. Please help these are priceless memory that I think I ruined, I'm freaking out Help!!!
    Champion:
  • 217 Answers
Yes there are ways to recover your priceless pictures, try memory card recovery softwares, there are many site available in the internet, or you may purchase in store selling digicameras. don't format your card!!! Norton may help too!
Posted on Sep 08, 2007
  • teofilo navarro
    teofilo navarro Sep 08, 2007
    A virus infection is present in your card, formatting is the only way to remove it. make it a habit to format the card first in your camera not in pc, before taking shots. ( do this every time you use the card in pc.)
    camera unit by the way does not get infected by the virus, you can't just operate it normally using infected card.
SOURCE:
Card error light flashing green
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Success
Mar 05, 2014 | Samsung L200 Digital Camera
Fujifilm finepix s2900
If the pictures are in the camera's internal memory, first copy them to the memory card using the Copy command in the Playback menu. See page 89 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s2800hd_manual_01.pdf
To download the pictures from the memory card to your computer, take the memory card out of your camera and put it into a card reader attached or built-in to your computer. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Oct 21, 2013 | FUJIFILM Cameras
Fault finding
The green LED is called the memory acces lamp. When you switch off the camera is will write back the last changes. when you switch the camera on and off, the light ususaly will stay off, because nothing has changed. When you remove the card en put in another the LED will flash again. At least my D7000 with 2 card slots will do so, because someting changed and the system will write that into the memory.
Aug 21, 2013 | Nikon D90 Digital Camera with 18-105mm...
How to remove card error in fujifilm jz300 camera
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | FUJIFILM FinePix JZ300 Digital Camera
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Camera and computer won't connect
Use a separate card reader to download your pictures.
Aug 29, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Reads card error and red light keeps blinking
Try cleaning the contacts on the memory card with a pencil eraser.
May 28, 2009 | Vivitar ViviCam 8400 Digital Camera
Camera memory card errors/computer doesn't recognize
Can you get a memory card reader that works for a Mac? If so then loading pic's to the 'puter through that route Flashing red and green lights have a meaning- what does the manual say?[Check the more comprehensive manual on the Software disk] You could buy[or borrow] another card- nothing wrong with having more that one. Also try the card in another camera and a fresh card in yours[Take it a photo shop to try this]
Jun 03, 2007 | Olympus Camedia C-450 Zoom Digital Camera
Lens stays in and camera will not power up.
hello, first of all try one thing, remove the memory card from camera and try to turn the camera on with fresh battery. if problem still remain try with another memory card. if your problem not fixed reset the camera. still not fixed run to olympus shop. good luck....
Jul 28, 2006 | Olympus D-460 Zoom Digital Camera
Fuji FinePix A205 Digital Camera Logo
70 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
