Question about Maytag Washing Machines
Maytag commerical washer model MAT10PSAAW COIN MACHINE . THE COIN VALUE IS 1.00 IT SHOWS 2.45 THE FAULT CDE IS dA5 how to reset to working status
    Problem Solver:
  • 4 Answers
I have been answering other peoples problems on this site I am a electrician . I still haven't fix my freind washer yet because the Code reads dA5 If I new what this code ment I could fix rhe machine . The machine is a maytag model number MAT10PSAAW SER AO592928MF
THE MACHINE IS A COIN WASHER 1.00 COIN . IT SHOWS 2.45 if I could get it back to read 1.00 ,I think it would work . Again the code is dA5. I have been searching the net . knowone yet with a clue .
Posted on Nov 27, 2008
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
Maytag front load washer mod mhwe251yg00 cde e1-f6
Serial communication error you have two computers one up top the CCU and one down below the MCU it's saying the two are not talking to each other the tech sheet has you go thru about 20 steps to basically come to the same conclusion it's either one or the other which I could help more but I run into the same problem in the field. Most times it's a failed CCU
Jan 20, 2014 | Maytag Washing Machines
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Blowing fuses
if you have a friend with a multimeter then you can trace the fault backwards from the plug to see when exactly the short circuit happens without plugging the machine into the mains using the multimeter terminals as the mains terminal and advance the timer by hand to see where the short accurses on the dial so you can see weather the short is the heating element or not that's the main cause of short circuits eric
Dec 26, 2017 | Maytag Commercial Non-Coin Washer,...
Maytag com dryer Model #MDE16PRAYW Setting coin Value
Unplug the unit, open the control panel, look for the instructions inside the control panel. program as needed. you will need access to coin vault and meter case.
Jun 03, 2008 | Maytag MDE16PD Electric Dryer
Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Nov 14, 2007 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
195 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
