Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco Vienna Coffee Machine water leak
It seems that the seal is broken between the water tank and where the water goes into the machine - it is leaking all over the work surface.
The machine is quite old but otherwise works OK.
Is there a way to fix this?
I have had the same problem with my Saeco Digital & Saeco Superautomica machines. After much work and somewhat expense I have finally found a simple fix. All you need to do is replace the gasket which is located just under the water reservoir.
(1) Take the water reservoir off
(2) Pop the round plastic piece located in the middle off (don't worry you won't break it as is it pretty tough)
(3) Take the black rubber gasket out and either:
(a) cover the present gasket with the brew group lube or
(b) replace the gasket with a new one.
which will give it a air tight fit and prevent any further water leakage from the reservoir.
You can get a new gasket for $5!!! :) I got mine at: http://cerinicoffee.com/item.asp?cID=0&PID=90
I also put some Brew Group lube ( http://cerinicoffee.com/Lube_brew_group_saeco.asp ) around the gasket as a temp fix until I completely replaced to gasket. Apparently, what happens is that the original gasket gets old, dry rots or whatever allowing the water to leak out of the reservoir. And then all over your work surface. The Saeco machines are quite intricate but are
Hope this helps.
-Dave
Posted on Nov 29, 2008
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Jan 21, 2013 | Saeco Vienna Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks coffe from under the machine.
1-Try changing the seal of the water inlet under the tank (part# NM05.006)
2- Check the o-rings from the water tubes coming in and out of the boiler.
Oct 19, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water leak
You have to replace the gasket where the water tank goes in to the machine.
Jun 28, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
When I make coffee, there is water leaking probably from the drain, even after I changed the seals with new ones.
there are several places where this machine can leak. Check all the connecting hoses from the boiler , they are just clicked in by holder pins.
Even the seal in the boiler itself can be worn.
Follow this link for diagram and parts ( unfortunately in spanish sorry for that)
SAECO VIENNA SA
Oh by the way the seal on the spout which goes into your brew group can be damaged too. Check that first
Apr 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
430 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
