Convergence perfect focus not working and double vision
I have a Samsung SP42W4HBX/XEU REAR PROJECTION TV SERIEL NO 31EX300589N. The convergence appears out and the picture is showing double vision and out of focus. Tried to do a perfect focus and it only goes to 22%. Manually, when tryingh to adjust the red an d blue in convergence setting pressing the + or - buttons to converge the colours does nothing. The red blue and white colours are all showing when i try to do a red convergence. Is this a straight forward repair or an expensive one that requires a replacemet board? The tv is about 5 yrs old and i have never had problems with perfect focus or convergence and have used it all the time to ensure things were focussed. I have been informed that both convergence boards need to be replaced and that nothing else will solve the issue as it is a corrupted board. Cheers paul
    Habit-Forming:
  • 166 Answers
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Posted on Nov 26, 2008
Tmtmail.co.ukmy samsung projection tv has double vision and i dont know how to amend the lens can yu please help thank you
double vision in a rear projection tv has several reasons. one is convergence magnets are out of tune. u need to tune them which is back side of picture tubes. u please observe that which color is producing the double vision. the lens are firmly fixed & therefore need not to adjust. other option is to adjust the convergence of tv by going to service mode by remote.
Sep 13, 2011 | Samsung Televison & Video
I recently bought a samsung hcn4226w at a yard sale for $50. Thought it was a good deal, but when i got home I saw the picture had a double image and the picture doesn't seem bright. After some tinkering...
This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
May 14, 2010 | Samsung HCN4226W 42" Rear Projection...
Cannot manually Converge Samsung PCL545R 54 in. Rear Projection Television. Perfect focus doesn't work either.
Try website like Tv repair World.com to buy a whole convergence board to replaced.Samsung/Akai use the same convergence board.
Apr 26, 2010 | Samsung PCL545R 54" Rear Projection...
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Perfect focus reads "no sensor data"
hope this helps check out this above links
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 09, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Televison & Video Logo
390 people viewed this question
Top Televison & Video Experts
