Question about AOpen AON-325D Network Adapter
I have one problem in my computer, there i saw is shuting donwn
Some timi and every time when i start my PC then it auttomaticlly open My document and there show me allway your computer is going to shut down after 50 minute. What is this and how i can solve this problem.
Some i solve this problem by using this following:
Run>Notepad>
then i wrote there in notepad    shutdown-a
then seve as then
i use like this.   ""   then i wrote there  "remove.bat" then i save it then can saw on desktop there remove.bat programing file. when i use this 2 or 3 time it auto out. but it allway so im feeling bored from this problem.
    Habit-Forming:
    New Friend:
  • 77 Answers
Go to settings ffnd out time out auto off adjust
Posted on Apr 11, 2017
Computer keeps shuting down
The fan area of your PC is probably stuffed with some rubbish which is sticking the fan and/or overheating it - which causes the PC to shutdown every few minutes.
Open your PC and remove the rubbish
Oct 04, 2012 | Computers & Internet
Dell dimension 370 randomly shuts down orange light flashes on pwr button
I suspect your graphics card or processor is overheating and shutting itself off to prevent damage.
Cool the unit down with additional fans, introducing cool air and exhausting warm air is key to a reliable, stable computer system.
The reason for this sudden problem is most likely because a higher resolution on the new monitor is supported, therefore making the computer work much harder than before.
Take care!
damnor01
Jun 09, 2012 | Dell Dimension Computers & Internet
I was trying to make my comp. load faster. A prompt popted up telling me that if I shut off some programs off on start up it would load faster. See it was taking 3or more minutes to just get to my screen....
hi timi you could try this ....restart the pc and when the first setup screen appears hit F8 key a few times it will go to a screen with a few options one is safety mode another is safety mode with networking and you'll see the option to boot from last known good configuration highlight that option by using arrows on keyboard and hit enter or retun key your pc should restart in proper mode...if not then try starting the pc even in safety mode and clik on start then all programes then accessories then system tools thn system restore give it a second then clik ok the default option that comes up on next window is the present day select another date to recover from then highlight a date that it was working correctly and clik next on bottom of window then follow instructions till it starts it will take about 10 mins to restore your pc to a date when it was working correctly and the pc will restart ...ok hope this helps good luck...bonnell
Sep 23, 2010 | Computers & Internet
Computer wont start.
I don't have access to your board details. However, beeps frequently represent memory problems. Try
removing the memory on your system and then putting it back.
You can access your memory on the bottom of your computer. It is likely the smallest rectangular hatch. After powering donwn the computer, remove one or two screws.
Remove the memory sticks by spreading the clips on each side of the memory. After removing them, put them back. This will clean the terminals and ensure a good connection. Before putting the back on, try to boot the computer. If you hear no beeps, all is good. Turn off the computer and put the hatch back on.
If you hear beeps, switch the memory modules. Try again. If you still hear beeps, try one module at a time in the primary memory slot. If one of these works, you should be able to buy a new memory module. Go to a sight like Crucial's and have it tell you what you can add. Perhaps this is a good excuse to upgrade.
You should do this at the kitchen table to avoid any static discharge.
May 20, 2010 | Fujitsu Siemens Lifebook N5010 Notebook
FR- 2.0 14'' Factory Reconditioned My
I am going to assume you are following the warm start procedure in your manual. Most start problems with 2-cycle engines are caused by flooding.
Before you shut if off roll it to the side and loosen the fuel cap (vent tank - leave it loose until restart) Better? Repair fuel vent. No better carburetor needs small adjustment. This explains it better than I can but you will need to experiment some.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Just because this is the most likely cause:
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
I hope you found this helpful. You can reply below if you need additional help.
Lou
Jan 17, 2010 | McCulloch Garden
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Laptop keeps shuting off
how old is the system
is this while running with ac adapter or battery or either
Oct 22, 2008 | Apple MacBook Pro Laptop Computer with...
Hello, i have a western digital 500gb my book hard drive. had a problem with pc yesterday. when booted up, lots of the programs started opening themselves and i had difficulty shuting it down. turned off...
You have experienced a system emergency shutdown. In otherwords, your computer crashed. You can:
1: reinstall your operating system.
2: use a OS recovery disk to reboot the system.
3: send the computer to a data recovery specialist.
4: return the computer if the warranty is still valid.
Good Luck!
Jul 05, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
