The red light is continously flashing but water container is empty. The conditioner does not get cool, I suspect because of flashing light. Ive noticed that pipe is squashed in two places. Do I need to remove and change pipe and will that fix it
Fast check your compressor have running if not,check relay & relay voltage if no relay voltage - So your electronics control device not work.
2nd - compressor have running - so your condenser or" capilary pipe lick- check lick if not - So check compressor read presser with gagemeter,check inlet,outlet volb.
SOURCE: CF 210 Delonghi
i just found out that e3 means voltage problems. i plugged my into a place i knew would have enough voltage and it started right up with ac
SOURCE: MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
SOURCE: I have ft error on delonghi air conditioner and
Theres a little floatation type device in the removable tank that triggers a switch just above the tank on the unit itself. Just check that that isn't stuck in the "Full Tank" position. I had the same problem and jiggled the switch to make sure it could move and my A/C was back. Hallelujah!!! Hope it works for you...
