My USB has sudenly stopped working when i put it into my computer it says device found but when i go to my computer it says please insert the USB disk HELP I AM GOING TO LOOSE ALL MY WORK
    Scholar:
  • 81 Answers
wow. you know, a virus or trojan program is running to your USB and that program will install to your PC. when you double click it and in continous pressing of enter tab. it will multiple thier numbers.
first thing you do is scan your USB before you open your save files inside. and the safest way to do and you have a continous update of your anti-virus. becuase the main transforter of Virus and Trojan is a USB storage.
hope this can help you.
God Bless
Posted on Nov 26, 2008
  • Alver Clamonte
    Alver Clamonte Nov 26, 2008
    adding to what i said, in your CMOS /BIOS setup make that your USB is Enabled.
    you can go to BIOS setup by pressing F2 or Delete Tabs in booting your system.
Panasonic CF-VDRRT3
Check your connections and cables. From the look of the thing it is designed to work from the USB port on a desktop computer, a laptop gives less power through the USB ports, this is why most USB powered devices for laptops have 2 USB plugs for connection.
Oct 02, 2013 | Computers & Internet
The computer couldnot read the outer hard why he told me to insert the hard and i alreay insrted him then the computer read him and suddenly stops working and told me again check that you insert the h
If you are talking about an external hard drive or external usb device that you put into one of the usb ports it might be bad. You could try a different usb port. Also try using it on another computer.
If it does not work on a different usb port or another computer then it's definitely bad.
Jun 05, 2012 | Computers & Internet
USB DEVICE NOT RECOGNISED: One of the USB device attached to this computer has malfunctioned and windows does not recognised it.
The problem you have stated can be due to several causes. Please eject your USB drive from your computer and insert it again. If windows does not detect it, then restart your computer and try again. If the problem is still there, please check the Device Manager if the USB port is properly working and if it is possible to use the troubleshoot. The best way to check whether your USB device is properly working or not, insert it to another computer other than your's. If the problem persists, check your USB device's warranty period and simply go for the replacement and contact your retailer or service provider.
You can go to Device Manger by following the steps below:
My Computer Icon>Right Click on the Icon>Properties>Device Manager
Thanks for using FixYa.
Hope this helps,
Mrityunjay.
Apr 03, 2011 | Computers & Internet
Wireless adapter not found please plug-in the DWA-120
After uninstalling it completely from the computer. When you plug in the adapter alone. You must get the "Found New Hardware" wizard. And nothing else apart from this. Only then it is correct. If nothing comes up at all, the device is dead or your version of USB might USB 1.0 or USB 1.1 which at times has issues. But if you see that wizard coming up, unplug the adapter and insert CD and run setup and walk through it.
Anyway, i ll recommend that you try this adapter on other NEW computer(laptop or desktop), just to check.
I feel that this adapter would work on a new computer, maybe your computer's hardware specifications are old to support this device.
copy.pngfavicon.icofavicon.ico
Jan 22, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
One of the USB devices attached to this computer has malfunctioned, etc.
This problem is caused by a USB ports of the motherboard. Try to insert the usb devices in the different usb ports and if all ports you inserted encounter the same problem then probably the ports has technical hardware problem. To solve this, buy an expansion usb card to your computer. Be sure also that the usb devices you inserted in your computer in properly working and has no defect to determine that the ports are the problem and not the devices. Please don't forget to rate me..Thanks..:-)
Oct 26, 2009 | HP LaserJet P2015 Printer
How to format corupted microsd
Before you start, please make sure you have a reader that can read and write to 2GB card properly. DO NOT use in built-in reader on laptop and desktop, or old readers made 2 years or longer ago, because these readers can only use up to 1GB card. I recommend using it in external USB 2.0 reader that is made within 1 year ago.
If you do not have such reader, then connect the device (gps/camera/pda/camcorder) to the computer with USB cable and the card inserted and if works you should see new drive letters show up under My Computer.
Otherwise, if used in devices that do not support the 2GB card, the card will be damaged.
Please try the following troubleshooting guide first and see if it can solve the problem. Try one step at a time. If one works, then you can stop trying. You don't need to try all of them.
The following guide will erase all the data on the drive/card. So make sure you backup your data first before you try the steps below:
1. First, remove the card/drive from your computer.
Download the low level format tool below to your computer.
http://hddguru.com/download/software....2.36.1181.exe
Install the program into your computer.
You should see a new icon called "Hard Disk Low Level Format Tool".
a. Insert the card/drive and run the program.
IMPORTANT!!! MAKE SURE YOU SELECT THE CORRECT DISK OR YOUR COMPUTER MAY NOT START LATER!!!
It should shows as BUS: USB. Select the BUS: USB. Also check the size and make sure.
If you don't see BUS: USB, that means the card is unreadable and need to be replaced. In this case, please STOP here and close the program and DO NOT continue below.
b. Then click Continue->Low Level Format->Format this Device.
c. Wait for a few minutes until it finish successfully with a message of asking you to partition and format it. (if you see formatting error, you can stop the formatting and the card needs to be replaced.)
d. Flash Card:
Put the card back into your device and then use the format utility in the device to format the card.
Sep 03, 2009 | Garmin eTrex Venture Cx GPS Receiver
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Installing usb cable without cd
you can not install the cable it is the device atteched with the cable that gets installed.to install a usb device with out cd insert cable into device and then the computer.you should see a small window that says :new device found: then installing device then:
installation failed no drivers found etc...now at this point you tell the computer to search online for appropriate drivers. if this doesnt't work write me and tell me what the device is and i'll help you find appropriate drivers
Apr 23, 2009 | Computers & Internet
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Teac MP 360 512 doesn't start.
yes, i have the same problem with the MP350 - unrecognizable device, won't start, and stops when usb-cable plugged-in...
i found the next solution... reflashed firmware(same version), plug usb-cable when device is off, and only then put it on, also put the cable only to 75%, enough for the pins to contaact, but not to toch the end of the device connector
found causes:
- when usb-cable is inserted deeply into the socket... some problem appears, may-be a short circtuit or other, don't know
- when used more than 890Mo of the memory... device dies
- using folders to put my music in - the problem appears only from time to time, even with almost full memory... so - may be problem of the flash memory
of course, i'm not an engineer... i just tested and tested and tested... and tweaked a solution that enables ny device to work at least
Nov 02, 2007 | Audio Players & Recorders
Computers & Internet Logo
Alun Cox
David Payne
David Payne
