Question about SimpleTech 160GB USB 2.0 / FireWire External Open Box (STIU2F36160OBB1) Hard Drive
External Hard Drive is not accessible or readable
When I plug in my External Hard Drive into my computer it shows up but when I want to open it, it comes up with an error of
E:/ is not accessible.
The parameter is incorrect.
I have a feeling it wasnt properly stopped before i took it out last time as it had frozen up.
I turned it off and on again to see if it fixed it and now all of a sudden it makes the same error but also sounds like there is a ball bouncing up and down inside of the hard drive!!! Can I fix this and save all my data or should I take it to a professional.
  • 477 Answers
I recommend that you take it to a professional. your driver has error on it and the expert should restore your data from it before the disk going stops working completely.sound like a harddisk hardware error.
Posted on Nov 26, 2008
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Dropped SmartDisk
Depending upon how hard the jar was to the internal mechanism, the data may be salvageable. I would guess that the first problem is broken connections at the USB connector. This case is just snapped together with a laptop drive in it. Carefully open it up and look for anything broken.
Worse case scenerio, you can get an adapter to plug the drive into a standard IDE cable inside your tower system.
Dan
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
When plugged into my computer, it acknowledges that it's been plugged in, however when i go to my computer to access my files, the folder doesn't show up.
Nalon:
Assuming that you're using Windows:
Assign a drive letter for the External drive.
  • Right Click on My Computer
  • Scroll to Manage
  • Select Disk Management
  • Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, and you should see your External drive with your new drive letter assigned to it.
Thanks for using FixYa.
Feb 13, 2011 | Western Digital My Book Essential 1TB...
I m using a Maxtor One Touch and since I m using a new computer I can't access my information anymore. Do I need a new software installed.
If the system you are using is a different operating system then the original, then that may be the issue.
If it is a Mac Journaled formatted hard drive, it would not show up in the Windows OS. In which you would have to do some transfer of your hard drive contents in a MAC OS to a drive readable by both. Or place them on network accessible location and copy it to your Windows Hard drive
Jan 12, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
When i plug in my WD External Hard Drive 500gb it show to be un readable in disk managen ment and gives no options to fix it
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 09, 2010 | Western Digital 500GB My Book Pro-External...
I plugged my external hard drive into my usb port where it downloaded the driver perfectly and it said everything was working properly. Then i went to my computer and the hard drive does not show up for me...
above the control panel there is a computer word
click on that and it shows the external hard drive double click on the hard drive icon and that will open up all of the files and folders on the hard drive
Jan 05, 2018 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
Frozen WD 250GB External Hard Drive
Can you try and access this external hard drive from another computer, if not, then try a system restore back to yesterday if possible.
Jul 24, 2009 | Western Digital Caviar WD2500BB 250 GB...
External Hard Drive not accessible
open your external drive and check for connections. the hd might be loose.
Mar 17, 2008 | Computers & Internet
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Computers & Internet Logo
823 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
