Question about Xante ScreenWriter (Refurbished) Laser Printer
My printer printing black - Xante ScreenWriter (Refurbished) Laser Printer
  • 48 Answers
Try another toner/drum cartridge also check contacts. If the problem persist replace your printer. Bad Main board or high voltage board most likely. Economical unrepairable.
Posted on Jun 01, 2009
Unable to print in black but able to print others than black
You may have blocked nozzles in the black print head.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 22, 2012 | Office Equipment & Supplies
My computer (PIXMA MP500) will not print in black. I installed a new black cartridge but it still will not print in black. It will print in color.
try to check were you put the black cartridge in the printer..check if the place of your black cartridge if it is cleaned and try to print then if it is still the black cartridge not print in black ask the technical of the printer and ask them the problem of the printer.
Sep 15, 2011 | Canon Pixma MP500 All-In-One InkJet...
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Hp laserjet 1320 printer printing problum the printing black black point.
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP LaserJet 1320 Printer
I have an HP color printer. When printing the black does not print well even though it shows that the black print cartridge has plenty of ink in it. Is there a way of: 1. Diagnosing if it is the print...
Nov 11, 2010 | HP Deskjet F340 All-In-One Printer
Samsung CLP-315 colour laser printer - is it true that you cannot print only with the black toner cartridge, if one or more of the colour cartridges is empty? I only need to print black!
Yes, it is true that most of Color printers will not allow you to print document if one or more of the recommended Cartridge of the printer is empty or removed from the printer. for printing only black, the better option will be to change your printer settings while printing a document. ex: when on a document ,and your press Ctrl+P for document printing, there is a option where you can select print color as black and the printer will print your document in Black only.
Feb 05, 2010 | Samsung CLP 315 Laser Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Xante ScreenWriter (Refurbished) Laser Printer Logo
95 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Igor Studennikoff
Igor Studennikoff
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
