Question about Sony Televison & Video
Wall Mounting Sony KDL40X2000 LCD TV
In the process of moving house and can't find TV manual. In new residence I would like to wall mount TV. Can you tell the size/gauge of the screws that screw into the back of the TV connecting it to the wall mount?? I have the bracket but not the connecting screws to the TV!!!
Many thanks if you can assist.............
5 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
SOURCE: Mounting the bracket to the tv?
Hey, I had the same problem and finally found this solution (the four mounting holes are covered by plastic caps as I thought ... just wanted to be sure). Hop this helps:
http://www.avsforum.com/avs-vb/showthread.php?t=1040337
Posted on Dec 27, 2008
  • 7 Answers
SOURCE: samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
Posted on May 22, 2009
SOURCE: Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Posted on Oct 25, 2009
budmrtn
  • 11361 Answers
SOURCE: Mounting a Toshiba 32HL95 on a Wall
Yes you can:
http://www.skakawack.com/wm11-3496.html
or OMNIMOUNT P/N U2-T, U2-F.
Posted on Oct 29, 2009
Testimonial: "Many thanks. The bracket claims that it is specifically good for the 32HL95, so I'll give it a try! Great response, thanks again, Dave"
How do I install a tv on my wall
First of all find out what size mount is on the TV. On the back of the TV you should see 4 screw holes to take the bolts of the stand. You can measure the space between the holes. Then you can search for a mount that will take that size. If the TV is big you will need a very strong wall mount.
When you get the mount it should have instructions for mounting it. But make certain the wall you are fixing it to can take the weight and is stable. Fix the mount to the wall, make certain that you use the correct screws and plugs for the screws. You should be able to tell if the mount is secure enough. If you have any doubts, get somebody in to do it. The mount will come with the correct fixing screws for the TV. You will need two people at least to fix a smaller TV to the wall and two people to hold a big TV while a third screws the mount to the TV.
Feb 10, 2017 | Televison & Video
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
I have 1 tv Thomson 32E92NH22 LCD and i lost the manual.I'm trying to get it hanged on the wall.No ideea what tipe of screw i need to conect the tv to the wall hanger.Can somebody halpe me?Thanx a...
Hi mona_77a,
You can find the manual for your TV here.
Your Thomson TV is compatible with a VESA FDMI (Flat Display Mounting Interface.)
These typically use "VESA screws."
VESA screws tend to be metric sizes of M4 (0.7mm pitch). The length is typically 10mm, but would depend on the bracket (if you don't have a gauge handy, just put a small stick of some sort in there and mark it off with a felt pen, then measure).
Washers are a really good idea, especially if you decide on thumbscrews with plastic heads.
You may be interested in eHow's tutorial on how to mount a flatscreen TV to a wall. This is for a 42 inch screen, but the same rules should apply with a 32 inch.
  • Open Link in New Tab
  • Download
Mar 01, 2011 | Televison & Video
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Dec 26, 2009 | Philips 42PFL3704D LCD TV
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Mar 05, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
214 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
