Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Fridge freezing everything,
Is 1 coldest in fridge or 6.
Give the clear info abt this product.
if it freezes a lot control the nob to zero
and check even then u have the same problem then contact your nearer mechanic and check the condensor.
Posted on Nov 26, 2008
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
What is the coldest setting on a Chefmate mini fridge?
Well, mine is set to 1 and it freeze everything in the fridge! I'm going to try the opposite
Sep 10, 2014 | Refrigerators
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Oct 22, 2013 | Beko Refrigerators
What setting is the coldest on refrigerator? it goes 1-6
#6 is the coolest on the fridge, with the #1 being least coldest to #6 being the coldest setting.
Apr 04, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Fridge temperature. 1 through 10?
1 is the lowest and 10 is the coldest. 6 should be idle setting you can have.
Hope this helps.
God Bless.
Jul 08, 2009 | Refrigerators
Thermostat setting on frigidaire bar fridge 1 - 10
10 is the coldest. Hope this helps you:) I keep mine at 6 and its great.
Mar 16, 2009 | Refrigerators
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
248 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
