Question about Philips Televison & Video
My philips DVD 728/051 plays a Green Screen on my new Panasonic LCD type 32LZD85 TV. The picture is there but in greencasts, sound is fine. If I turn off power to DVD for 24hrs & reconnect the picture works fine. But when playing several hours later the picture is green. The DVD works ok on other TV's in house.
  • tltlbear May 11, 2010
    does the tv work ok with anothr dvd?
jaffa012001
  • 376 Answers
SOURCE: How can I unlock my
I think the following should work for this player-
  • Power On the unit and Open the tray
  • Slowly press 9, 9, 9 and then 9
  • Press 0 for region free
  • Close tray
Note: If the above code doesn't work then attempt the same operation with the tray Closed instead
Posted on Aug 04, 2008
SOURCE: black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Posted on Oct 16, 2008
Danmart
  • 291 Answers
SOURCE: Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Posted on Nov 07, 2008
SOURCE: Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Posted on Feb 22, 2009
  • 63 Answers
SOURCE: dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
Posted on May 02, 2009
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Feb 27, 2009 | Philips Magnavox MWD200G DVD Player
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
New Toshiba 32'' - sound gone funny
on your remote control click menue and than select sound and go from there
Oct 16, 2017 | Toshiba CX36F84 TV
Finding Recording/Playing Channel on TV
Make sure there is a yellow video cable (or one of the other types of video cable) running from the Philips to your Panasonic. Make note of how the TV labels that source - Video 1, Video 2, Component 1, etc. Use the TV/Video button on your Panasonic to change the TV to the appropriate input channel - Video 1 or 2 if you used a yellow video cable, Component 1 or 2 if you used a red/green/blue cable, etc. Now, make sure that the Philips is in Disc mode by pressing the Disc button on the Philips remote. You should now have picture.
-Tha Mp3 Doctor
Oct 22, 2008 | Philips HTS-6500/37 System
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Televison & Video Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
